Results 1 to 15 of 24
Thread: Largest Motor In 200x frame
    Aug 2009
    la
    36
    Question Largest Motor In 200x frame
    Whats the largest motor someone has stuckin a 200x frame with or without modding it? What challenges did you face? Does it offically run? Was it worth the trouble? Ive heard from a friend of a friend of a friend etc.... That someone stuck a motorcycle engine on one. Interesting.
    Mar 2007
    Texas
    5,045
    if willing to mod, then nearly anything. I've seen 250r motors in there and 500r started, but the guy ran outta $. (200x frame lighter than 250r)
    what are you trying to do?
    ________________
    https://www.mikesatvfix.com
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    This was posted in another thread.
    If it's true, then it's pretty darn cool! Oops, just realized, that's probably not a 200x frame.
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    CENTRAL NY
    1,709
    Thats Sandpuppies 600X.. I believe its a mix between a 350X and XR600 frames..
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Willamstown PA
    5,824
    not much fits in a 200x frame. if you hack it up anything can be made to fit. but prob you sprockets wont line up in the end cuz those motors were not as wide as other bikes.
    You'd be surprised what fits in an 86/87 style frame
    But, I always tell people, how many good conversions do you see?? We know the people that have the tools and abilities... Otherwise, any meatball can stuff any motor in any frame, and it never works well and gets sold for peanuts.
    Want more power?? Build the motor!! Performance engine changes don't add any weight to speak of...................
    Aug 2009
    la
    36
    Thanx for the info guys. i Guess its best to work from the ground up instead of stuffin it. And i didn't know that the 200x frame is lighter. Is it the LIGHTEST 3 wheeler frame?
    Mar 2008
    Tug Hill
    1,282
    isnt bigbores 500x a 200x chassis?
    Jul 2006
    iowa
    451
    xr200 and 230f dirtbike engines will bolt in for the most part, and give a pretty healthy power gain. I put a tlr200 dirtbike engine in a 200s of mine, and the only major problem is the kicker. I have a parts 200x engine, and the plan was to mix and match parts to end up with a 6 speed manual clutch 200s with a forward kicker and 200x head/valves/and camshaft. I haven't gotten around to finish it, but I did take it for a few rides with the 6 speed tlr engine.
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    Jul 2006
    Quote Originally Posted by lndy650 View Post
    I believe thats a nicholsons frame wich used 200x parts like tank/plastics
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    yamahaman on here stock a 450??? 500??? street bike motor into one.. i think it ran?? but didnt stop.. i cant reember
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    Willamstown PA
    5,824
    xr 200 motors do not bold in 84+ i tried, an RFVC motor is nearly as big as a 86/87 200x motor. 83-02 xr200 motor fits but no mounting points mount up really, i know because i trided. if you mod the framw it fits in there fine.
    Feb 2003
    Australia
    927
    ???? 83-02 XR200 and 83-85 200X have the same center cases so they do fit including the head. All the bolts line up perfectly. The RFVC engines don't fit but they are crappy anyway.
    Nov 2009
    Provo UT
    31
    In my local classifieds about a month ago someone was selling an 85 200x with cr500 motor in it for $500. it was a little rough around the edges but still looked bad A .
    I called him up and the guys brother ended up in the hospital for 2 weeks and wanted to get rid of it.
    I tried to call him back to work out a deal and I could not get a hold of him.
    Mar 2009
    Fallbrook CA
    137
    I measured it out at one point and a blaster engine will go in, and a 490 engine isn't much bigger.
    1984 kxt250 tecate
    1982 185s pipe, carb, cam won't give it up.
    1984 200x dead organ donor
