I'm sure most of you have seen my previous thread about reviving my ATC 110. I've purchased a new carb and it seems to have a valve problem.
After I put the carb on I sprayed carburetor cleaner down it to see if it would run for a little bit. It sprays the mist right back out of the carb, although I did get it to fire a couple of times, blue smoke came out of the carb then. I think there is either crud holding the valve open, it is burnt, or bent. I guess the timing could be off also, but it looks ok. Any ideas on what it could be before I pull the head?
and an 85 atc 70
. I also removed the spark advancer weights, but can't seem to get the plate off that they were mounted too. Is there a key or something holding it in? Should it just slide off after I remove the bolt.
