Thread: tightening up a loose kickstart?
    Oct 2009
    Rogersville, MO
    94
    My kickstarter on my 350X is really "sloppy" and loose. I took it off and as you can see the ball roller has rubbed a path, and it doesn't lock firmly at either end. I started to take it all apart, but after taking off the C clip that pin still won't come out. Any suggestions???
    Oct 2009
    Rogersville, MO
    94
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    if thats whats sloppy and loose, you can
    A. get a new one
    B. take it apart, machine bushings for it, re-assemble
    C. take apart, weld-fill the pin holes, re-drill out and re-assemble.
    if you have no access to machine shop tools, then the easiest and cheapest option would be option A
    Oct 2007
    Minneapolis mn
    4,067
    ^^^ I rebuilt mine on my 86... That was back when I worked in a machine shop... Just as 300rman descibed... Worked like new when I was done...
