Thread: Size for front fender bolts
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    hey guys i just recieved a new front fender for my 83 200x and do not have and pre existing 4 bolts to hook the fender up with, i want to go buy some but unsure of the size and length i need. any help would be much appreciated. Thanks
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Dec 2002
    Orange County, NY
    1,772
    Take a look on one of the Honda parts look up sites. The fender's are mounted with rubber grommets and steel sleeves as far as I've seen so you'll need them to properly mount the fender. You can just do it the hack way and bolt it straight to the lower triple clamp but then it won't have any flex. The bolts should be 6mmx1.25 pitch. I'm not sure on the length though. Of course the length for doing it the "right" way will be different than if you do it the hack way.
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    6mm x 1.0 pitch and probably 25mm/30mm long.
    1,25 is for 8 and 10mm most of the time..........
    Dec 2002
    Orange County, NY
    1,772
    My mistake, I meant 1.00.
    1986 Monstecate
    1984 ATC125M
    Jun 2003
    englishtown NJ
    2,676
    honda likes 1.25 pitch bolts, all of the 8, 10 and 12mm are 1.25 pitch. The swingarm bolt and front axle is 14mm 1.5, axle ends are 18mm 1.5(most honda's) and 85-89 250r/350x are 20mm 1.5.
