Thread: 200x problems
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    200x problems
    Hey guys my 83 200x that i restored in the summer is starting to give my some problems, brakes nothing major but my Big problem is that it will fire up first kick runs and idles awesome but when i put it into first gear the clutch basket either won't engage or something. Although if running and someone give me alittle push the bike will go into gear and i can proceed to shift through all 5 gears smoothly. I don't kno a hole lot about working with the clutch ect. so if you guys could give me some advice/tips to fixing this problem because i would really like to ride the outta this thing this winter. Also maybe some suggestions on what i should buy in the way of some rear tires for this bike. Definitly no trail pro's lol
    Heres some pic's of my bike also after i restored it this summer. I know the white plastic tank is abit yellow, but it's a hole lot better then it was before i sanded the outta it.
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    matt86200x's Avatar
    Apr 2009
    Canada Eh!
    366
    ill try again
    Attached Thumbnails Attached Thumbnails IMG_1288.JPG   IMG_1289.JPG   IMG_1291.JPG
    85 250sx
    86 200x
    86 350x
    Feb 2009
    michigan
    2,387
    sounds like the clutch is worn?springs worn?any grinding?clutch cable adjusted properly?
    1985 ATC 250R
    . Team Red Trike
    matt86200x's Avatar
    Apr 2009
    Canada Eh!
    366
    What kinda rear tires should i get for this bad boy?
    85 250sx
    86 200x
    86 350x
    matt86200x's Avatar
    Apr 2009
    Canada Eh!
    366
    Also does anyone know what kind of jetting i should be doing to my stock carb after i installed my bassani exhaust?? not experienced with jetting requirments at all
    85 250sx
    86 200x
    86 350x
    Nov 2009
    1,147
    If you rock it foward/backwards a few inches will it go into gear then?
