Results 1 to 7 of 7
Thread: 84/85 Tecate with 85/86 LT250R motor
    Sep 2005
    MICHIGAN
    2,027
    Here is a picture of a 84/85 T3 with a 1985-86 Suzuki LT250R motor in it.
    Looks to have the stock LT pipe.
    Anybody ever seen or tried that?
    86 T3
    84 T3
    86 KX250
    Nov 2006
    southern oregon
    2,338
    no thanks... i would rather have the kawasaki vibes than have that ugly pipe and funky pistonport/case reed engine
    2-stroke lover
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    Quote Originally Posted by cr480r View Post
    What do you mean by that? It looks different but not for me.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Tecate250 View Post
    i mean that the early quadracer engines have less power potential than the KX based tecate engines.. the only thing the suzuki engines have going for them is a better ignition system and counter balancer.. other than that the kawi engine is superior in every way and it fits like it was meant to...
    2-stroke lover
    Sep 2005
    MICHIGAN
    2,027
    probably not a great option but still an option. Lot more LTs and parts for them around.
    I looked at putting a 87-92 LT motor in an 86 T3 and it was a tight squeeze but looked possible. I was more interested in the swingarm fitting on there which also looked possible with minor modifications to bolt on but then there was the whole shock geometry. Never got that far.
    86 T3
    84 T3
    86 KX250
    Mar 2005
    ma
    988
    the old lt engine would probably be the easiest engine to get in there. as the exhaust exits on an angle to clear the front down tube. swingarm bolt diameter is the same. just have to make front and lower engine mounts. but that pipe doesn't look right, probably try the stock tecate pipe. probably fit better.
    you'll also be slower. i have an 86 lt250r. its a fun quad but slower than a 85 t3.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Nov 2006
    southern oregon
    2,338
    the back of the engines are almost exactly the same width. the chain alignment is only .100 different. so a lt motor in a T3 would just need the rear sprocket shimmed out.. much easier than using a t3 motor in an lt chassis where the engine must be offset... i loved my lt250,
    but they are not built nearly as well as a kx or t3 powerplant IMO.
    2-stroke lover
