Thread: atc185 hub?
    Jan 2005
    Eastern PA
    95
    atc185 hub?
    So i have an 82 atc 185 i just recently bought a suspension front end from a 185 thats what the guy said. However it seems the hub is a little larger and wont fit inside a front rim that i got off a 200s. What rims will work?
    Honda Atc 185-toy/snow beast!
    KX250f-race bike
    Klx110-pit bike
    6,809
    Quote Originally Posted by trimoto55 View Post
    I believe your looking for the large 2 piece 9" steel wheels that have a 4/155mm? bolt pattern . A-lot of the early honda atc with the 25" tires ran that rim . It would probably make it easier if you just pick up a hub and wheel off a 200s and use that .
    Jan 2005
    Eastern PA
    95
    well i just bought a brand new tire for the front and my hub is perfvectly good i dont feel like spenind more money into this trike that i need to im already way over from what i originally expected. I just need a rim with a large enough center to fit this hub
    KX250f-race bike
    Klx110-pit bike
    6,809
    Thats the problem the 9" rim is the only one that will fit that large hub . Is your new tire 8 " or 9" ? That large honda bolt pattern is a tough one to get away from . Measure your bolt pattern in inches and let me know I might have a rim for ya or a front hub set up too.
    Jan 2005
    Eastern PA
    95
    ok i need a hub assembly off a 83 185. This hub i got doesnt even line up to the forks let me know what got send pm
    KX250f-race bike
    Klx110-pit bike
    6,809
    I have a correct front hub and brake set up but no axle or spacers for it . You can place an ad in this site and i'm sure someone will have a complete set up .
