Thread: What's Interchangable Between 84 200X and 86 200X
    Nov 2009
    1,147
    I found a donor 86 200X. Are the motor mounts the same even though they changed the frame designs?
    Also are the engine covers the same? Says the 86 is only missing some covers for the engine and its the 6 speed 200X.
    What else is interchangeable between the two years?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    the grips,,,, other than that nothing...
    Side Wayz's Avatar
    Side Wayz is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    S. Jersey
    279
    pretty much whole different trike ground up. Bigger engine 199cc 83-85 192cc.Box frame compare tothe reg. tube. Sux.
    Aint' no wayz like side wayz!!!
    84 200X (SOLD)
    84 250R #17 AirCooler Current Racer
    85 250R (in progress parts needed)
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Rear wheel hubs from the 86 can be used on the 85 to make it wider, front fork tubes interchange (not the triples), the front brake caliper and mount interchange, the rear brake caliper will work if you use the 85 bracket, complete front wheel and hub will fit the 85, the front master cylinder will work on the 85 (use the 85 brake hose). I think the headlight and shroud will fit the 85 and it looks nicer IMO. You could use the handlebars, clutch lever and thumb throttle on the 85 and maybe the carburetor with some jetting changes. Other than this stuff, nothing else I can think of.
    Don't worry...just run watcha brung...
    Mar 2007
    Texas
    5,045
    may consider doing up the 86 as it's a much more valueable trike.
    ________________
    https://www.mikesatvfix.com
