Thread: Rear srocket '83 ATC200
    Nov 2009
    Okauchee, WI
    555
    I need to replace the rear sprocket on my '83 ATC200. I took off the left chainguard cover and gave it a lok over. Taking the chain off looks no prob. The rear sprocket looks like you take 4 bolts off and it should 'slide' right out. Kinda like it's bolted to a hub on the axle rose. Am I correct? The front sprocket looks like it's held on with a couple keeper nuts. Will this 'slide' right off or is it pressed on too? Thanks.....Matt
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    i know on a 82 200 you there arent welded nuts on the backside of the dampening assembly, so you have to take out the axle to get the sproket off. its pretty easy. just take off the chain and wheeles, then dissassemble the brake assembly and slide the axle right out. sometimes the drum is a pain to get off because of rust, but theres a trick to it. once you get all the covers and what not off, you might have to put some wd40 or something in the brake drum splines. before you do this, get a needle, or an extremley skinny pair of needle nose pliers and take the O-ring out from between the drum and axle. then after a little wiggling and spraying, it should come right off.
    Feb 2009
    Rome,NY
    1,046
    on the motor side it is just the 2 bolts and it slides right off
    Nov 2009
    Okauchee, WI
    555
    Where can I buy a sprocket? I looked on Bike Bandit and it looks like it's not available .
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
