Page 3 of 3 FirstFirst 1 2 3
Results 31 to 41 of 41
Thread: Fat Cat 250sx
  1. #31
    Mar 2011
    powell r canada
    17
    very nice ,I'd also like to make a fat cat out of one of my trikes. how did you connect the drive shaft, and what wheel did you use. and was the suzuki hub the same width as the swing frame?
    Thanks Dan.
  2. #32
    May 2014
    Pennsylvania, US
    12
    Do you still have the fat cat. If so, how has it held up? Did the drive shaft work without any mods?
    1985 Honda Big Red 250es
  3. #33
    Dec 2007
    Quebec,Canada
    1,014
    I still have it and never had ANY issue with it.Reliable as the stock 250sx.Drive shaft need modification to fit.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
  4. #34
    Oct 2014
    Edon, Ohio NW corner
    71
    That thing kicks ass!!!!!! I have several SX's and would love to do this.
  5. #35
    May 2014
    ottawa ontario
    17
    Do you have any pics of how you made up the shaft?
    thanks! looks great.
  6. #36
    Feb 2015
    Very nice unique build.
  7. #37
    Dec 2007
    Quebec,Canada
    1,014
    No sorry no picture of the shaft.It's simply the gs and sx shaft welded together with a bushing over it.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  8. #38
    Worcester, MA
    1,117
    Is the brake assembly aluminum? How did you weld it to the cable mount you added in the rear? Looks like steel to aluminum?
  9. #39
    Dec 2007
    Quebec,Canada
    1,014
    Cable mount is steel and welded to the swingarm
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  10. #40
    Jan 2020
    St. Cloud, mn
    Nice build! I'm looking at doing the same. I have a question regarding the rear wheel. Did you just use/modify the rear driven hub assembly from the GS650? How'd this work with the SX rear drum brake?
  11. #41
    Dec 2007
    Quebec,Canada
    1,014
    Basicaly,it's a modified 250sx rear Wheel (removed about 1 inch in the middle),a 250es front hub modified (so I used the 250es drum brake),the gs650 rear end drive on the Wheel,check picture tou can see how it's installed on the rear wheel
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
