Results 1 to 7 of 7
Thread: Stripped bolt on 200x air filter
    Oct 2009
    Tucson, Arizona
    90
    Whats's the best way to get out a stripped bolt? I have a really bad stripped bolt on right on top that "L" shaped piece of metal that holds the filter in place. I've even tried those stripped screw extractors with my drill. But still haven't had any luck. Any secrets you guys got on taking out really bad stripped screws/bolts? I really need to get a new air-filter!
    Sep 2007
    100mi west of Chicago
    3,582
    Is it a broken off bolt or are you able to get vise grips on a little piece of it? Can you post a picture?
    Rob
    Oct 2009
    Tucson, Arizona
    90
    No it's not broken off, just stripped real bad, sorta looks like a bowl on top. I can take pics of it tonight when I get home and post them in the morning.
    Mar 2004
    Fond du lac,WI
    658
    try to get a vice grip on it first or get a drill bit a little smaller than the screw and try to drill it out
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Slot it with a hacksaw or die grinder with a cut off wheel. Use a flat screw driver.
    1985 Kawasaki Tecate 3
    Nov 2009
    1,147
    If you use a screw extractor make sure its a good one, the edges on the cheap ones are dull and don't bite on the whole you just drilled. The cheaper ones look more chrome and the edges are dull and the ones that work better are a high carbon unfinished steel, the egdes look sharp. Spray on some penetrating oil (PB Blaster is the best I've found). Give the screw extractor a few light taps with a so it bite into the bolt, then use a small cresent on the end of the screw extractor, turn it slowly while pressing down. I've never had any luck using a drill, the drill wants to turn to fast, and it just slips out.
    Feb 2009
    michigan
    2,387
    Quote Originally Posted by 85Tecate View Post
    2nd that dude
    1985 ATC 250R
    . Team Red Trike
