Thread: 200X brake line
    Feb 2009
    Liberty NY
    49
    200X brake line
    I am currently in the middle of updating my 1985 200X and I have put on a rear brake master cylinder and reservoir off of a 2006 HONDA CR 80. My problem is now my brake line that runs from the master to the brake caliper is to short. Any Ideas on what I can do? I'm sure guys that use extended swing arms run into this all the time.
    Nov 2009
    1,147
    Buy a longer brake line, most hydraulic shops can custom make whatever you need if you bring in the old line.
    Feb 2009
    Liberty NY
    49
    checked the local auto parts stores by me and all they can do is large hydrolic lines they can not get the correct fittings. Anyone else?
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    I put together a stainless steel vinyl coated brake line from parts ordered at www.jpcycles.com. I forget what size fittings you need exactly, either 10 or 12mm (I think it goes by the size of the banjo bolt if I remember), but you can get any length you need and any type of fittings for the ends. They are a bit pricey, but should last forever.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Nov 2009
    1,147
    Check a place that specalizes in hydraulics, maybe not everywhere has them. But check under hydraulic repair in the yellow pages. They can usually make a nice set in stainless or regular hydraulic line.
