Results 1 to 9 of 9
Thread: Carb rebuild...Wont start 200x
    Nov 2009
    Davenport, Iowa
    7
    Need help Rebuilt the carb with kit did it by the book. And now it wont start i kick and kick it will rumble to a start really sounding like its missing and quits. My pilot screw is 2 out and ive been messing with air screw help me please
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Quote Originally Posted by blake.latham View Post
    Did you make sure the pilot jet was the same number as the old one? I would check that, and for air leaks. 1 1/2 to 2 turns out should get you close. Make sure the bowl is full of fuel.
    1985 Kawasaki Tecate 3
    Nov 2009
    Davenport, Iowa
    7
    yes pilot did not get changed due to the moose carb kit had wrong pilot screw. was easy to tell the new one had very fine threads vvvvv versus stock VVVVVV so i didnt use
    Nov 2009
    Davenport, Iowa
    7
    i will check fuel bowl
    Sep 2007
    100mi west of Chicago
    3,582
    Pilot screw is the same thing as the air screw. Do you mean you are messing with the idle?
    Rob
    Oct 2007
    Minneapolis mn
    4,067
    If it had the wrong pilot screw, what else in the kit was wrong? I had a kit for my BR that had a wrong primary jet... a 180 (suppose to be a 45!)
    Mar 2009
    Iowa
    442
    Quote Originally Posted by Thorpe View Post
    I agree. I would send the kit back and get the correct one. You might have the wrong needle jet (which could be sticking in the seat and not allowing fuel to get in) or one or both of your jets are the wrong size. Also the fuel screw is probably wrong. Dont use that kit. Theres a reason theyre not interchangable!
    Feb 2009
    michigan
    2,387
    after checking all that above,make sre you didnt bend the float tabs.
    1985 ATC 250R
    . Team Red Trike
    Mar 2007
    Texas
    5,045
    i think the jests are incorrect and either not flowing or flowing too much.
    ________________
    https://www.mikesatvfix.com
