Results 1 to 9 of 9
Thread: Riding too Hard?
    Mar 2009
    Fallbrook CA
    137
    Riding too Hard?
    Has anyone here ridden so hard the oil in your forks flies out the schrader valves on top of your forks? Excuse to put the 85 front end on I think?
    1984 kxt250 tecate
    1982 185s pipe, carb, cam won't give it up.
    1984 200x dead organ donor
    I'd imagine there is a hair too much oil, your bottoming or the air valve is leaking...........
    Mar 2009
    Fallbrook CA
    137
    It's bottoming, hard! I was trying to keep up with XR650s in whoop sections.
    How well do the 84 tecates respond to porting changes? It feels like the motor has a lot of horsepower hidden in there, or are they just not all that fast?
    1984 kxt250 tecate
    OK
    5,450
    They respond well to porting, any 2 stroke will. Or you can get the 83-84 KX cylinder that outperforms the KXT cylinder by a long ways. Then you can port the KX cylinder and be even faster.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Nov 2006
    southern oregon
    2,338
    you can do all the porting you want... but that tecate will never keep up with a motorcycle through whoops...
    2-stroke lover
    Aug 2009
    Newfoundland, Canada
    915
    not to hijack the thread, but how do you port? do you just basically take some material out of the ports with a dremel, or do you need a pro to do it?
    BTW, you can never ride too hard ya know
    Mar 2009
    Fallbrook CA
    137
    I know its not the best idea, but This thing could realy use a lot more yank!!! I normally ride big bore bikes and require a power delivery that doesn't pull, it hurls you foreward! I'm working on the suspension issues. Is the Dg pipe any better than stock or is it like the IT490 and the oddessy where it is just a replacement?
    Who makes a good exhaust for thiese things?
    1984 kxt250 tecate
    Nov 2006
    southern oregon
    2,338
    yes the dg is better than stock. It might not be the best, but it works quite well imo..
    2-stroke lover
    Mar 2009
    Fallbrook CA
    137
    Any advice on how to increase the power of this motor or am I just going to need a husky 510 motor?
    It has the ricky stator, ohlins shock, richter silencer
    1984 kxt250 tecate
