Results 1 to 11 of 11
Thread: Splitting Cases-ATC90- I'm Scared!
    Oct 2008
    NB, Canada
    852
    My 90 has a horrible oil leak on the center case gasket. I've got it apart right now on the clutch (right) side, I've got the clutch and everything out, and all I have left to do is remove the screws and split the center of the case, but before I do I want to make sure that I don't screw something up.
    I've heard that with the 200's that if you split the case from the wrong side all the gears will fall out. Is this the same with the 90's? All the screw heads are on the side I'm working on, so I assume this is the right side, but I want to make sure.
    Anything else I need to watch out for?
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Oct 2009
    brazil indiana
    836
    first off, Red Green is awesome! love the pic. as for the case halves, after you take all the screws out. you will want to lift off the right case (the side that the clutch is on) and let the crank, gear sets, and shift drum stay in the left side. it may want to lift the shafts out of the left side so watch close to all the shafts to make sure they are staying down. after the two sides are apart you will see that it is not that bad. just make sure that after you get the right side off that you look inside of it to make sure that a thrust washer did not stick to that side. these washers like to stay on the case half and need to be put back where they came from. there should only be one that could stick to it but i am not sure of that. i think there is one on the counter shaft only.
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Take pictures, they help alot. Try to keep as many parts grouped together as possible if you take them completely out of the cases.
    1985 Kawasaki Tecate 3
    Oct 2008
    NB, Canada
    852
    The Red Green show is Canadian, so I grew up watching it.
    Thanks for the help from both of you!
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    A few taps with a rubber mallet and your chicken!!
    $ strokes pop right apart, 2 strokes sometimes need to be "pulled " apart I imagine because of the clearances......
    Take your time, keep the bench clean and well lit and make sure every part goes back where it's suppose to.
    GLUCK!
    Oct 2008
    NB, Canada
    852
    I just got back it from getting it apart. Everything stayed in place, and I don't have to take any of it out because I'm just fixing a leaking gasket.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Feb 2009
    michigan
    2,387
    go slow and dont guess where stuff goes back together.know where and how.should be fine.good luck.
    1985 ATC 250R
    . Team Red Trike
    Oct 2008
    NB, Canada
    852
    I've had the clutch and every else off before, so I should be good from here. I was just worried about the transmission gears falling everywhere when I took it apart.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Oct 2008
    NB, Canada
    852
    I've been putting it back together and I've got the clutch back in, but I've been having a problem. The arm the disingages the clutch when you shift slips by the piece on the clutch when I shift. I know this problem was there before I took it apart.
    What would be the best way to fix this?
    I though about bending the arm a bit closer to the clutch, but I don't want to break it.
    I can get pics if nobody understands my problem.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Oct 2009
    brazil indiana
    836
    Quote Originally Posted by Gearheadtom View Post
    i think i understand what you are talking about but don't know why it would do it. do you have it on the right spline/ angle? is the arm bent back toward the shaft? on the end of the arm, the side that is toward the center should be parallel to the center. if it is not it may be bent. you should be able to bend it back if that is the problem but if it is not the problem then you will need to find out why it it that way.
    Oct 2008
    NB, Canada
    852
    I just bent it a little toward the clutch, and now it seems okay, but after I put the outer case back on with a gasket (I've been testing it without) it may need to be bent a little more.
    Thanks for the help.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
