Results 1 to 8 of 8
Thread: Gas petcock question
    Nov 2008
    Coon Rapids, MN
    956
    The petcock on my gas tank has been froze ever since I owned my Tri-moto so I can't change it from on to reserve, I had a spare one that I tried soaking it in WD40, PB Blaster and mixed gas and I still can't get the plastic barrel to turn inside of the aluminum petcock housing without breaking the cast aluminum lever, if anyone has an idea on how to get it to break free please help also does having the gas on all the time wear the needle and seat out in the carburetor faster?
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Feb 2009
    michigan
    2,387
    buy a new one, cost per time is not worth it.time is money ya know.
    1985 ATC 250R
    . Team Red Trike
    6,809
    The yamahas use a tapered plastic type valve that gets stuck over time . If it comes apart just clean it good and try that .
    Nov 2008
    Coon Rapids, MN
    956
    I tried pulling it apart and I still can't get the plastic barrel valve to slide out of the aluminum petcock housing.
    Thanks, Alex
    My feedback.
    My album
    Nov 2008
    Coon Rapids, MN
    956
    I can't find this part new so does anyone know of a chemical that will eat the white corrosion from the aluminum petcock housing without damaging the plastic barrel valve inside.
    My feedback.
    My album
    Oct 2007
    Minneapolis mn
    4,067
    If the aluminum is that coroded, and you manage to get it apart, the thing will probably be so pitted it will probably always leak...
    Nov 2009
    1,147
    Have you tried the one on yours, maybe its less corroded? You could try a very mild acid like white vinegar to dissolve the corrosion, or coke.
    You could try blowing it out with an air compressor, or some carb cleaner, into the end that goes into the tank.
    How long did you soak it in PB Blaster?
    Nov 2008
    Coon Rapids, MN
    956
    Both petcocks are corroded same way. Thanks guys for all the help
    My feedback.
    My album
