Results 1 to 15 of 30
Thread: '86 200x HELP!!!!!!
    Dec 2009
    fort wayne, IN
    Exclamation '86 200x HELP!!!!!!
    just recently bought a 1986 Honda 200x and plan on restoring it this winter...dont know alot about them and i have a couple questions. there is almost a grinding sound coming from the front tire when i take off....1st and 2nd gear i think. also, there is smoke coming out of the exhaust constantly. lastly, back brakes dont work. any help would be GREATLY appreciated!
    Aug 2009
    Newfoundland, Canada
    915
    lift the bike off the ground and spin the front tire. if there is any strange sound, your front bearings are gone. what color smoke is coming out? there are a few guys on here who know alot about the master cylinders for the brakes, and they will chime in sometime soon
    welcome to the addiction
    Dec 2009
    fort wayne, IN
    the smoke is like a whitish/bluish color. doesnt smell funny, just smells like exhaust to me. i was thinking the bearings but some guy told me that my forks might be best and thats why. It kinda pulls to the left but thats because it needs air.
    Dec 2009
    fort wayne, IN
    do you know of any places to get the bearings? this is all that ive found so far
    http://www.hyperparts.com/wc.dll?ctw...01~000259#0001
    Trimotomike's Avatar
    Trimotomike is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2008
    Crystal River , FL
    233
    If the smoke isnt black then chances are you need a valve/topend job done on your machine , the grinding noize like he said is probably wheel bearings . If your forks are shot they will either bounce like a pogo stick or freeze up either way forks probably arent the culprit . As for the wheel bearings the first place i would look would be ebay . good luck
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    Aug 2009
    915
    allballs bearings are what I run in the front of mine. whitish blue smoke means its burning oil. your going to need at least a top end rebuild with new rings. good luck
    Dec 2009
    fort wayne, IN
    Quote Originally Posted by MudBug View Post
    oh jeeze....i guess i have all winter to learn. is it hard to rebuild the top end? i heard 4 strokes are hard as hell to do compared to 2 strokes
    Aug 2009
    915
    they are harder, yes. but you probably dont need to do anything with the valves, but it couldnt hurt. everything else is simple. just order a top end gasket kit, new rings and if you can get the cylinder honed it would be good but its not necessary. once you crack her open, you will find that its much easier than you think
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    mudbug anymore progress on that 250es you been workin on?
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Parts:
    Alot here. Where i get my stuff from... http://dratv.com/200x86to87.html
    Aug 2009
    915
    Quote Originally Posted by matt86200x View Post
    what a coincedince, I just updated the thread
    Monroe MI
    5,787
    It's all simple with a manual....
    Problem is, if the motor burns oil it msy hsve never been cared for before you. Once oil levels go low, the cam journals starve for oil, the rocker arms and shafts starve too.
    It can cost a fortune to fix, but used parts are out there! and the 200SX quad has your same top end.....
    Get a manual, read up on it, tear it down and see whats junk..... They build it up to snuff and have a ball!!
    Jan 2008
    Crystal River , FL
    233
    A 4 stroke rebuilds not as hard as you think, all I ever worked on and rebuilt were 2 strokes until my 185s started smoking . Few more parts to it than a 2stroke but its still do-able if you are mechanically inclined to some extent . Once you rebuild one its cake .
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    Feb 2009
    michigan
    2,387
    you have good advise already,download the manual and follow.ask questions if you dont know.and rings only go one way,there are three of them.they can not be interchanged.
    1985 ATC 250R
    . Team Red Trike
