Results 1 to 15 of 19
Thread: 200x Wobbles!
    Oct 2009
    Tucson, Arizona
    90
    200x Wobbles!
    Last night I did an oil change & replaced the spark plug. After I was done I went out for a quick ride around my block and I noticed that my trike would wobble? Only thing I could think of was the spacers I put on it? I went back home and made sure all the nuts/bolts were all on securely. Checked 'em and went back out to see if it would still wobble, well it did! I don't know what it is that's causing it? Has this happened to anyone? Please Help!
    Oct 2009
    Tucson, Arizona
    90
    Anybody have any idea why my trike wobbles?
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Take the spacers off and see if it still wobbles, if so then you've found the problem. Are the spacers new? They could be tweaked or something. Bent rims could cause the problem too, or a bent axle, but check the spacers first.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Oct 2009
    Tucson, Arizona
    90
    Quote Originally Posted by Solid Snake View Post
    Well I rode the trike about 2 weeks ago without the spacers, and it was fine no wobbling! I just put the spacers on last week for stability and took it out for a ride last night and now it wobbles! the spacers arent new, they are used. My rims aren't bent and neither is my axle, never had the problem when it was stock? Could it be that maybe the spacers aren't alligned when I bolted them in?
    Feb 2009
    michigan
    2,387
    most likely something is not aligned properly.make sure spacers fit flush with the rims,and the hubs.
    1985 ATC 250R
    . Team Red Trike
    Oct 2009
    Tucson, Arizona
    90
    Quote Originally Posted by harryredtrike View Post
    I'll have to check it when I get home. I wanted to ask on here first, just to see if maybe someone else has had the same problem?
    Oct 2009
    Tucson, Arizona
    90
    If I rode it before without the spacers and it ran perfect (no wobbling), it would have to be the spacers right?
    louisiana
    1,499
    quickest way to find out if its your spacers is to r,ide it without them
    Signature pic removed,becuase of no helmet.
    Oct 2009
    Tucson, Arizona
    90
    Quote Originally Posted by leevarnado View Post
    Well I did ride my trike about 2-3 weeks ago stock without spacers and was fine. I added the spacers for more stability and took it out for a ride and it wobbles.
    Rode stock without spacers = No problems & no wobbling
    Rode with spacers = Wobbling
    Could it be that I just need to take the bolts/nuts off and re-tighten them?
    Daltons200x's Avatar
    Daltons200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Levittown, PA
    183
    well if u rode offroad befor and on the street now you could have a slightly bent axel and you dont notice it in the dirt. and the spacers just amplified the bend causing a noticable wobble. i rode a 200x for 3 years and never had any problems off road but on the street the thing wobbled all over
    Rides:
    1983 suzuki alt50
    1985 honda 200x
    Sep 2008
    845 New York
    2,302
    im with him
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    my 200x wobbles on the street also.. untell i air the front tire up more than it is slight, in the dirt its glass smooth
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    Monroe MI
    5,787
    These are the plastic spacers from this post?
    http://www.3wheelerworldforums.com/s...d.php?t=105786
    Do they sit flush on a flat surface, both sides?
    Post a pic of one, when you get a chance.
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    pleastic spacers??? nooooo thank you!! ill stick to my durablues with grade 8 hardware
    Oct 2009
    Tucson, Arizona
    90
    Quote Originally Posted by Daltons200x View Post
    * About 2 months ago I went trail riding with some buddies. I took my 200x out stock with no spacers. Rode perfect with no problems! Previous to that she also rode perfect without wobbling off-road and on street.
    * Took it out and rode it around my neighborhood couple days after the trail ride. It was still stock w/no spacers and rode perfect with no wobbling on the street.
    *About 2 weeks ago, put on spacers and didnt ride it that night until I did an oil change couple days ago. So I take it out for a spin around the block and now it wobbles?! I'm thinking it could maybe be the way I tightened the nuts/bolts. Because I was missing 1 nut on each side for the wheels. So I went out to ace hardware and picked up the 2 nuts that need replacing. I had tightened the 3 nuts/bolts that were on there. and when I got the last nut from ace hardware I went home and screwed em on. So I'm thinking it could be that they are just not tightened equally onto the hub! I haven't had a chance to check because I've been getting home late. I will take pics tonight and post them tomorrow AM.
    Would it have anything to do with my tire pressure in the front or rear tires? too much, too little?
