Results 1 to 15 of 16
Thread: Help with rim/tire size. 84 200x
    Nov 2007
    Can someone school me on tire size and rims. I have a 84 200x with the factory rims. Im gonna buy a new set of tires for the rear and want to run around a 18" tire. I will not be running this on rocky/rough trails. Mostly just dirt and some mx tracks. Any suggestions on tire size/brand/pattern and preformance would greatly be appreciated. What kind of rims and sizes would I be looking for. Places to buy rims/tires?
    I want to keep my factory rims with the lumberjacks I have mounted on them for easy switch.
    Oct 2009
    Tucson, Arizona
    90
    I would also like to know what rims/tires fit an '85 200x? Would they be the same as the '84 x? Do the newer Honda 250's or 400 ex rims fit?
    OK
    5,450
    Yes, 4X110 all of the 200x's, 250R's, 350X's, 300EX's, 400EX's, and 450R's have the same bolt pattern. If you use the hubs from a 300EX or 400EX it will give you I think 2 inches more width.
    Here is a link.
    http://www.mud-throwers.com/atv_wheel_chart
    And as for the wheel sizes, 18" tires will cause you to have to regear your 200X to get it back to where it was with the larger tires.
    Here is another link. This one will show you the change in gear ratio from the teeth you have to the teeth you will need to maintain the same rpm at the same speed.
    http://home.earthlink.net/~gellett/tecate3.htm
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Williamstown PA
    5,825
    stock tires on the rears were 22x10x8 anytires that are 8" rim fit. www.tiresunlimited.com
    just buy some maxxis razr's in 18x10x8. i had them my last 200x and they worked great.
    Williamstown PA
    5,825
    300ex/400ex rims and 250x rims give only .75" per side. i measued. offsent rims give you 1" perside
    Nov 2004
    OH.
    2,487
    I use this chart. Copy and saev it. It's very useful.
    Oct 2009
    Tucson, Arizona
    90
    So if I go out to the swap meet and find some honda wheels/tires for example from a 300ex,400ex, or 450. I will be able to go home and just bolt them onto my trike with no problem or having to re-gear my trike?
    OK
    5,450
    Quote Originally Posted by AZ.45 View Post
    Yes, they will fit.
    Rides:
    My feedback thread
    Oct 2009
    Tucson, Arizona
    90
    Yes, they will fit.
    NICE! Thanks!
    Nov 2007
    Thanks for the info and links
    Lancaster, PA
    1,738
    WELL.....yes they will fit BUT....stock 300ex type wheels have a thicker center then the 200x wheels or douglas wheels, you will need to use a tapered lug nut (stock had flat lug nuts) and may have to grind off the little tab on the 200x hubs. If you go with 300ex type hubs , no problems and they bolt right on. Just some info for ya.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Oct 2009
    Tucson, Arizona
    90
    Quote Originally Posted by blue27 View Post
    What tabs are you talking about on the 200x? If its what I'm thinking of, that may be the problem I'm having with my wheel spacers i just put on and for some reason my x now wobbles?
    Feb 2009
    Rome,NY
    1,046
    i use the 400ex rims/tires/hubs they work very well in all but the super muddy spots
    Lancaster, PA
    1,738
    here is a pic from ebay, right under each stud there is a small tab that sticks out, on the 300ex wheels the rim hits these tabs, just grind them down. If you need better pics I can go dig out a hub,
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
    Nov 2007
    Anybody got pro/con of a 18" vs a 20" tire. I know ground clearance is one thing you lose with a 18". Im still trying to decide if I should go 18 or 20 in the rear.
