Results 1 to 15 of 19
Thread: question about cam/carb
    muddog's Avatar
    muddog is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    Manitoba
    225
    I was wondering if I could get more power out of my '86 250ES by changing carb and cam if so any suggestions? any help will be appreciated Thanks.
    Aug 2009
    Newfoundland, Canada
    915
    get a web cam and a 350X carb with the big red jets. vent your airbox and get a better pipe and youre on your way
    Feb 2009
    michigan
    2,387
    Quote Originally Posted by MudBug View Post
    x2 on that
    1985 ATC 250R
    . Team Red Trike
    mike1979 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Michigan
    406
    Not to hijack but how about an atc 200, would a 250sx carb make an improvment.
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    Its not an easy bolt on.
    And a red 2000 silverado
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    for carbs i have a keihin cvk34 from an 06 400 arctic cat laying around that wouldn't by any miracle work would it?
    mike84bigred's Avatar
    mike84bigred is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    North Tonawanda, NY
    343
    I'm using the original carb., but haven't dialed it in yet. Since I know nothing about carb. jetting, its in the shop right now. Tell ya what though, cam and heavier springs and a Cobra exhaust system, really uped the torque.
    84'200s (Dad bought new in 84, long gone)
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    84' Big Red (Cobra exhaust,good shape) sold in 08
    84' Big Red (Parts Bike, runs good though)sold in 08
    85' 250SX (New plastic, Clark Plastic Gas Tank, Web Cam Camshaft, Cobra Exhaust, Moose Jet Kit, etc..) sold in 2010 and highly regret!!!
    04 Polaris Sportsman (Swapped 400 motor with a 500, Polaris wheels w/Kendra Bearclaws, Moose Fender Flares, Brushguard, Warn Winch)
    84 200s (Needs work!)
    May 2009
    LaSalle, MI
    313
    I would worry less about aftermarket carb and more on aftermarket exhaust and good working stock carb.
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    this thing has enough low end to flip over backwards without ever sitting on the back. i just want some more mid-range power, get there quicker type a deal. Where would i be able to get hold of a good(cheap) exhaust?
    Using a manual isn't that like cheatin?
    There ain't quite nothing like the smell of diesel fuel in the morning!
    Aug 2009
    915
    denniskirk.com has a full cobra pipe for the BR for like $110. Which is a really good price for a new pipe. Just remember the copper crush ring that you put in between the header pipe and the motor. its like a gasket. Mine never had one and it made her run terrible
    Oct 2006
    North Tonawanda, NY
    343
    You have to get the carb rejetted after you put an exhaust on!!! Trust me, it won't run right. Oh, and expect to make a smoke show for about 5 min. when you start it. About a foot of the header pipe paint will desinagrate!!!
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    Aug 2009
    915
    sounds like youve had some bad experiences recently!
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    about how much more power would this add and what sizes of jets do you guys recommend
    Mar 2009
    Fallbrook CA
    137
    make sure its not the utility version of the cobra, made that mistake before, If you aren't mud riding, then just remove the airbox all together and go with a clamp on UNI. As far as a cam goes, a web cam stage II is what you want, way more mid and top end power. The cobra with jetting, and airbox mods alone will royally improve the "yank" factor for you.
    You don't want to know the actual numbers, because they are pitiful and will throw off your opinion of the end result, you are never goig to make it into a 30 horse howler, but the seat of the pants feel will make you feel like you have a hot rod.
    1984 kxt250 tecate
    1982 185s pipe, carb, cam won't give it up.
    1984 200x dead organ donor
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    thanks, the cobra is advertised as megaphone. what size of jets should i start with and where to get a cam from.
