its a plug with 1 green wire comming out of it.Looks like a sensor of some kind.
i took the left side casing off cause my chain broke it and found it broken.
83 Honda 200 E Big Red
98 polaris 100 4 wheeler for the kids
86 Honda TRX 250..Need parts for it.Let me know if you got any.
thats your ground wire coming off your stator
1985 ATC 250R.Team Red Trike
cool thanx for the fast reply.
think i could just soldier the wire back on then it will work since its just a ground wire?
It's the neutral indiator Green/red wire are always neutral signal
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
yea he's right,didnt look close enough the first time.
damn ok ...the wire come apart from the sensor and a little of the plastic on top was broke..you think it will work if i reconnect the wire?
will that part being bad keep me from having spark?
Humm not sure,ground the green-red wire,if you got spark the system need a neutral signal to start.But on the 200e if i'm correct,neutral signal isn't needed,start in any gear.250SX and ES start only in neutral,electric and kick
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
cool..im gonna assume that it will keep me from having spark then..can anyone else comfirm this?
also anyone got one of these sensors forsale? lol
i know the eletric start doesnt work if its in gear..has to be in neutral
