Originally Posted by
shortline10
I just explained this in another thread yesterday so here it is again .
Timing is a pain in the butt sometimes so this is how I do it (very simple) . Remove the flywheel bolt , Point the flywheel key directly centered at the head and this makes the piston @ TDC , make sure the cam lobes are both pointing toward the block or it will be 180 out . make the cam sprocket dot point the same direction as the flywheel key toward the top head cap centered . Align the cam sprocket up with the cam and bolt it up and your done . Flywheel key and cam dot both pointing away from the block and its good to go and cant be off .
I'm pretty sure I got that process nailed. Both valves open when they should and it has good compression. I'm having trouble getting the points aligned properly so they spark at the right time.
Would it run even poorly if the ignition timing was a little off or does it have to be dead on to run?
1999 Kawasaki Bayou 220
1980 Honda ATC110 (Work in Progress)
