Results 1 to 3 of 3
Thread: Trans Missing gears when shifting
    Feb 2009
    Wisconsin
    521
    I got a 125m, all the gears work. But when shifting it, it likes to go to neutral between gears like 1 neutral, 2 neutral and so on. But the neutral light doesn't come on so I'm thinking its just getting stuck in between gears. Is there a worn part that would cause this?
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Dec 2002
    Orange County, NY
    1,772
    Mine does the same thing. The shifter also seems to be very sloppy on mine. I think the two problems are related. Here is the reply I got when I asked about it over in the ATC70 section of www.glamisdunes.com:
    It could be one of the following. One of the little pins in the shift drum is broken, the shift lever inside the motor has a bent or broken spring or bent or broken claw. Either way you will have to take the clutch cover off, clutch and trans gear too. This will give access to the shift drum and and all the mechanism that moves it.
    LINK
    I noticed that with mine, it will go into gear almost every time as long as I push the shifter all the way. However, all the way on it is a REALLY long way. I've yet to dig into it.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Feb 2009
    Wisconsin
    521
    Cool, Thanks!
    2001 400ex
    1983 110
