Results 1 to 6 of 6
Thread: Question about drilling rims out?
    Ontario, CANADA
    4,538
    I run nothing but ITP rims on my trike. The baja ones have a bad habit off egging out. I know of multiple that have done this.
    I know its not helping that they one side got a little loose, anyways besides the point.
    Can I drill out ITP rims to the stock honda hole size and use the self centering OEM nuts? I like them alot and ran a whole season with them in the egged out rims haha.
    Will this comprimise the rim? Can this work???
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    I wouldn't do it on those without the tapered insert....
    I guess you could add a small dowel pin at each hub leg. Or tighten the *&&^*^%&^%$#$ out of them!!
    N/A
    5,818
    maybe if you made some type of spacer to fit in the larger hole and press fit it in like a sleeve?
    CENTRAL NY
    1,709
    Ive redrilled them using a hub with no studs at a template, but kept the holes the size of the stud and used a flanged nut havent tryed it with the acorn nuts..
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    I bought a set of Douglas wheels for my Tecate last year. When they arrived I quickly realized that they were advertised as the wrong bolt pattern. I didn't have time to send them back, so they refunded me some money and I used my wheel spacers as a template and drilled them out. The Tecate does not use those centering cones or whatever you call those things, they just bolt on. They did have a little bit of wobble to them, but I never got to find out if that was due to the composite wheel spacers that are less than accurate, or my measurements being off. I'm hoping it was the spacers. But yes, it can be done.
    N/A
    5,818
    wheel spacers can give wobble
