Results 1 to 7 of 7
Thread: snorkel
    Dec 2009
    souther illinois
    35
    snorkel
    i was wondering if anyone knew what hoses need snorkeld along with my homeade airbox snorkel i already have?
    Nov 2008
    Coon Rapids, MN
    956
    Any breathers that come off the carburetor and motor needs to be snorkeled
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Anywhere there is oil or heat should have a vent to let positive air pressure created by heat to escape. Any case with gears and oil will likely have a vent hose on it. Examples being truck differentials, transfer cases, engines (PCV valve), even tail rotor gearboxes on Blackhawk helicopters are vented. You may find vent hoses on drum brake setups too (the SX rear brake for example); this allows the positive air pressure created by the heat that occurs to escape, without having to push through and possibly damage any seals. On a single cylinder engine like a 200cc Honda, the crankcase vent allows air to rush in and out of the case as the piston moves. The piston is displacing 200cc on the combustion side as well as the crankcase side. You can feel the air moving if you put your hand above the end of that hose with the engine running.
    Factory vent hoses are typically painfully short and are a easy way for water and other contaminates to enter. Lengthening these hoses and raising them on the machine is a good way to combat this. Many people put them to the top of the steering neck on their wheelers. If the hoses can be put somewhere that will likely stay dry that's even better. (Some offroad trucks I've seen have run them into the cab)
    On my SX, I put all my vent hoses into my airbox; which I then snorkel when I come to a water obstacle. Those hoses include the crankcase, rear differential, and rear drum brake. The hoses are simply pushed snug through holes I drilled in the top of the airbox. I put them at the top of the box just in case water gets in there too. With this setup I have not contaminated my fluids as I did with the stock setup.
    Proper venting and guarding against contamination is critical and often overlooked.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Nov 2008
    ontario
    1,055
    name brand is right, people think that because the breather on their honda is up at the handle bars it will stay running under water. the crank case breather only goes to about the seat height. you are going to want to silicone the air box lid and cdi cover. and dielectric grease all electrical connections such as the spark plug boot. you may want to think about an exhaust snorkel so you don't have to rev it wide open to keep the water out
    proud owner of a trx300ex quad and an 85 atc 70
    Dec 2009
    souther illinois
    35
    hey danial u got any pics of cobra exhaust?
    does it sound good?
    Loud?
    Nov 2008
    ontario
    1,055
    Quote Originally Posted by live2rideatc View Post
    does it sound good?
    Loud?
    http://www.youtube.com/watch?v=rpZPnBYMk_Y <<<<---there, my other vid shows you just how deep you can go with the crank case breather rerouted and the air box sealed
    Zach's Avatar
    Zach is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Enumclaw, Wa
    262
    pretty deep
    1986 350x
    1985 250es Big Red
    1985 200m - sold
    1984 225dx - sold
    JCPenny Scat Tracker
    1977 atc 90
    2002 custom Suzuki Volusia
    1983 XL250R
    1975 XL175 (needs alot of work)
    1965 S90
    Proud Owner of 1 Set of Trailpros
