Results 1 to 15 of 15
Thread: 200m slipping
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    200m slipping
    Hey guys, been awhile since ive been on here, sold the 200e and got a 200m free the other day! Seems to be pretty solid and whatnot..... The only thing i found when i got it was that it was bone dry on oil, so i filled that and no leaks.... But now...
    Been playin in the snow with it, and all seemed fine, but then i took it out on the road and opened it up yesterday and noticed that 3rd & 4th seemed to "slip" a bit after shifting into them and getting on the throttle. It would wind up before it got the power like it was slipping.....
    Where should i start to tear it apart and look for a culprit?
    The clutch springs?
    Tranny gears?
    Could cheap oil do this?
    Thanks guys!
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Jan 2005
    RI
    2,530
    i would think its the clutch pack. Those auto motors have 2 clutches...a centrificial and basket type...i would tear it down and ipsect what you need and do it all at once. I am pretty sure you can do it all in frame. Get a new gasket and a clutch puller if you do not have one.
    There is a clutch adjustment but i feel that your fibers are shot. I need to do this on my 200s motor (same as M but no ESTART)...
    I plan on just pulling the motor and do everything at once...bore hone piston kit, cam, valves, all clutches, etc etc...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Feb 2009
    303
    I figured it would have to do with the clutches, but wasn't sure. Ill have to tear into it soon...
    Will it hurt it if i ride it like this and fix it right before spring? I mainly ride around the driveway area, and thats about it, just pull the kids around and do some donuts and stuff like that....
    Tusk Hand Guards
    TAG handlebars
    Jan 2005
    RI
    2,530
    run it...mines been slipping in 3rd and 4th for a few years
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Tionesta, PA
    5,747
    What kind of oil did you use? I have heard some kinds of synthetic oil will make clutches slip. Also -try adjusting the clutch before you tear anything apart!
    ^^^ x2 on that advice. Before you do anything get some motorcycle oil and adjust that baby right. Then go from there. It might be fine. ^^^
    Zach's Avatar
    Zach is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Enumclaw, Wa
    262
    and if it still moves it doesnt need fixed
    1986 350x
    1985 250es Big Red
    1985 200m - sold
    1984 225dx - sold
    JCPenny Scat Tracker
    1977 atc 90
    2002 custom Suzuki Volusia
    1983 XL250R
    1975 XL175 (needs alot of work)
    1965 S90
    Proud Owner of 1 Set of Trailpros
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    The oil doesn't have to be synthetic to cause slippage in your clutches. No new automotive oil is good for wet clutches, not one. You need an oil that has the MA rating on it.
    Feb 2009
    michigan
    2,387
    i agree with above,adjust your clutch and use a quality motorcycle oil.then see what happens.probably be putting in new clutches though.youll be able to ride it while you wait for parts.
    1985 ATC 250R
    . Team Red Trike
    Nov 2006
    southern oregon
    2,338
    i have revived many slipping clutches by scuffiing them up and changing oil type. i IMO no need to buy a clutch kit unless its burnt or worn beyond spec.. I am about to do this on my 200s... i noticed last time I had it out that it slips while upshifting under power... it holds fine if I let off the gas when shifting or just keep in one gear... i want to upgrade the springs. has anyone tried heavy duty springs or used springs from a different application?
    2-stroke lover
    CT
    116
    When I had to do the clutch in my 200s, the manual clutch (clutch pack), was fine and it was the centrifugal clutch that was toast. I have a very hard time believing you can wear out a clutch pack when you have a centrifugal clutch seeing as how they are def weaker. I would check that and clean it all out any way there is the oil pump in side the centrifugal clutch that needs to be cleaned out while your in there. Normally you will see grooves in the clutch drum of the centrifugal clutch and if thats the case you need a new drum! I would start with adjusting it and if that doesn't help then just pull the clutch cover its a very easy job that wont take you long at all.
    big yeller's Avatar
    big yeller is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    southeast texas
    247
    mine been slipping for a while so i put some 20w50 motorcycle oil in it with a bit of lucas oil stabilizer it helped out. i can take off better now it doesnt slip hardly at all. i was going to run it till i get a little time to fix
    1984 yamaha 200k
    1985 honda 70...some times swap the 125 lifan for fun
    1984 honda 200es
    1985 honda 200x
    atvs:
    2013 Honda Rancher 420 ES
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Quote Originally Posted by Mikeproc View Post
    Any idea what a new centrifugal clutch drum is worth?
    CT
    116
    Quote Originally Posted by ilmoakw View Post
    When I bought mine it cost 100 bucks brand new oem. I went with parts unlimited weights and pads.
    new york
    I'M GOING TO PUT A 2006 TRX 450eR WITH HRC POWER UP KIT, INTO THIS 85 250r
    ROLLER,,,,,,
    Any suggestions on how to go about it?????,
