Results 1 to 12 of 12
Thread: Do people want theier 83-85 200X brake pedals tightened up or??
    Question Do people want theier 83-85 200X brake pedals tightened up or??
    I have one here, thats getting done for free including the bushing and 2 o-rings.
    If I go forward with this, I'll move it to the R and D Forum, but for now I need to know who's in or am I wasting my time because I don't even own an <85 200X. I am merely trying to find small jobs that ship cheap that provide you guys with desired results.
    I have to machine your (small) side cover and remove/weld/replace the pedal pivot to accept a larger bushing and 2 orings.
    This places a bushing over the aluminum that wears on the side cover, which can then be replaced i the future.
    For the ultra repair, I can machine it all for a needle bearing but the bearing alone is not so cheap. It needs a hardened sleeve to roll on so I don't think many guys will jump on that bandwagon........ But, it is the ultra fix and an option.
    Anyhow, if you send me your small cover and pedal I am going to try and do this for about 30-40$ with ALL new materials installed/included. It will take me well over an hour - closer to 2 hours to machine and weld in the new pedal pivot. I have jigs to build and heat to run in the shop along with grinding discs etc etc..... Just being honest!
    If it gets sloppy again, it's about 5$ for all the seals and bushings (you can buy) to tighten it up again and you can do it at home with a vice and simple hand-tools.
    In the past, people had to buy that small cover (I believe it is DC'd as of now) and find or buy a nice pedal in order to tighten it up.
    I'm not asking anyone to commit/etch this in stone. I just need to know if it's worth me even doing because I want to buy 20 bushings and 3' of material to keep costs down.I would also make a jig so the pedal pivot would be reworked back in the stock location.
    If I get enough, I can powder coat them for a reasonable amount. But I can't do that if I do one at a time....... Ovens/Compressors etc all cost money to run.
    I've layed it all out for you, if your interested please let me know in this thread before I commit my time and money only to do 2 or 3 of them. I'm fairly sure no one will be able to do it any cheaper with the same result..........
    You won't hurt my feelings, just please run your thoughts my way.
    Oct 2009
    Missouri, United States
    62
    If I had an old 200X, I'd definitely send one your way. But unfortunately, I don't.
    TRIKES:
    84 ATC125M
    85 200 M
    83 ATC110
    QUADS:
    85 TRX125M
    01 Blaster
    08 SunL 110
    87 Yamaha Moto4 200
    DIRTBIKES:
    78 XR75 Restomod
    2009 SSR125 Pit Bike
    82 XR200R with Powroll motor
    78 RM80
    Chinese Z50 Knockoff
    82 XR80
    Phoenix, AZ.
    6,719
    I have to check my 200x project and see what kind of shape the brake pedal assembly is in. If it needs work, I'd be in BUT, not for a little while. The new job is taking way longer to pick up than I expected so I'm pretty deep in a hole right now.
    Nov 2009
    1,147
    I still wanna have it done, but I'm hoping to get an extra pedal and pivot off flee-bay so I can keep riding, and with X-mas I am broke. So I can't really say when, but I will want to have it done. My PVC pipe is only temporary. So I can't really say when other than once I get some cash coming in.
    I know it's only been an hour or so......
    The thing is that in the past I have offered to do some "fixes", bought the material and then only had 2 or 3 people have that stuff done. So........... Before I spend about 70$ on enough materials to do 10, I just want to make sure I can do at least 10 of them to be worth my time and effort. Or, I'll go down to the hardware store, buy a bronze bushing and repair the one I have already machined.
    I know my old 85 200X pedal was trashed LOL!! and I sold it to a guy/ex friend that never paid my father back the rent money he owed him; So, I hope he isn't a member here or I won't ship anything withing a 20 mile radius which is where he lives. Oh, and if you are a member and see this - Thanks so much BRETT for FKNG my family over after I did so many freebies for you. I won't do it again, LESSON LEARNED
    Nov 2007
    ulysses pa
    1,231
    im in for this steve, i have 2 covers but only one pedal right now. i'll hunt for another pedal so i can have both done at the same time. contact me here or ericandwende@gmail.com when your ready to start having them shipped. oh yeah, any idea on total cost pc'd?
    Dec 2009
    the ville illinois
    477
    I would be interested in geting at least one done.I have the original motor from my 2nd x and its sloppy.Whenever i find a new eng. I might want it done too depending on its condition.The running x is not too bad, but might get it done after I get the first one done so it dosent have to be down.
    Baltimore, MD
    6,088
    Do you have anymore info on the ultimate fix? What total cost might be? I need to do one of these for the laydown 200x engine.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    ^ Probably 35$- 40$ with all the machining and parts.....
    Thats reworking the aluminum (some covers may be too far to save)
    I have to grind a cutter and make a jig so I don't have to re-center every one......
    Powder coating is this weather is hard for me and I can do it cheap if I can do a few at one pop!
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    I will want one done for sure....but the big thing is that I really won't be ready until this summer. It's a project that's in pieces right now...I don't even know how sloppy the pedal is(never rode it)...I just remember when I took it all apart that I was wondering what parts were missing that caused that pedal to be so loose....and when I looked at parts schematics, I couldn't see what was missing. So I'm sorry to say that I'm not with ya timing wise and that I hope you are still interested in doing this 6 or 7 months from now.
    Dec 2009
    the ville illinois
    477
    hey dirtcrasher....when are you planning on starting this project??
    Feb 2009
    michigan
    2,387
    bump,just want everyone to get a chance to see this thread.dc got enough orders to do this?mine is still tight or id do it.
    1985 ATC 250R
    . Team Red Trike
