If the Pipe on the left is the correct one for the motor package your running then the one in the middle will (most likely) be totally wrong. The length and diameter is different, the cone angles and lengths are different, and the stinger size looks diff. also. The way the pipe was sectioned is not good, the curve is not smooth and the abrupt change in diameter can 'clip' your pulse wave, turning it into a complex wave form that does not stuff the cylinder the way its supposed to (even if the pipe is the right shape), and can in fact draw most of the charge right into the pipe in a worst case scenario (best case scenario the complex wave dilutes the incoming charge with spent gasses). This is especially true near the exhaust port as in the first 9 or so inches of a pipe it is very important to have consistent bends and correct divergence angles. Dents and dings in your pipe after this point usually don't have an adverse effect on power, as long as they're not major, and sometimes enhance it slightly. The smaller stinger diameter will, with no other changes, likely increase top end power output at the cost of high engine tempertaures and lower end torque output. Shortening the pipe increases tuned RPM and reducing the diameter generally decreases wave strength. The combination of the two is at best disastrous. High RPM and weak pulse waves mean lots of fresh air/fuel in the pipe. Sorry if this isn't the answer you were looking for,
NEMPD.... soon
85 ATC250R 40whp
81 ATC450R Elsinore Hillshooter
K0 US90
If cleanliness is next to godliness and brake parts cleaner cleans EVERYTHING, is brake parts cleaner a gift from god?? Think about it.
