Thread: 250SX battery reloading problem
    Apr 2003
    Qc,Canada
    489
    My battery is not reloading good!
    I did a multimeter test on the battery, and when my SX wasn't running, it was 12,54V, i started the engine, it was now 12,48V and when i was giving a lil throttle to it, it was 12,52V....on my dad's Fourtrax it climbed to 14V when he gave it some throttle...
    I changed the left-side cover (with the part on it, of course), and it wasn't working anymore...help me plz !!!
    Go big or go home!!
    Current rides:
    '85 250SX - Sold...I had no choice! Need money...
    '93 Fourtrax 300 4x4 (27" Super Swampers)
    '95 Yami VK 540
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Hello,
    Sounds like your stator assembly is no good or not connected. Check your connections and if they are hooked up your stator is bad. With the engine running you should be reading at least 1 volt higher than when the engine is off. Just went through this on my bike also. On my bike the starter reduction gears broke and the metal pieces got into the stator and chewed all to pieces.
    Good Luck,
    Apr 2003
    Qc,Canada
    489
    I changed the stator, so im gonna check at the connections
    Go big or go home!!
    Current rides:
    '95 Yami VK 540
    Howdy's Avatar
    Celina, Ohio
    10,079
    I got a 250sx motor in my golf cart and it only gets a 13volt reading during rev'ing. As long as it increases I'm not worried.
    Howdy
