Results 1 to 14 of 14
Thread: yt125 carb problem
    Dec 2009
    oregon
    116
    Question yt125 carb problem
    hey guys i have a 1980 yamaha yt125 that runs great. today i was playin around in the snow and i was climbing a little hill in the feild next to my house and when i got to the top the throttle was stuck wide open, scared me to death...lol. does anyone know why it would do this and how could i fix this so it doesnt happen again?
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    either the throttle cable is binding somewhere or your slide is sticking in the carb. check your throttle cable route first and see if there is any kinks or if its worn. good place to start.
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Dec 2009
    oregon
    116
    the thing is is that i shut it off and waited a minute and started it and it was fine
    Dec 2009
    Whiteland, Indiana
    69
    slide was sticking probably
    1981 Tri-Moto 125 - Parting Out ( LMK if you need parts! )
    1981 ATC 250R ( Rebuilding the engine)
    1984 ATC 125M - SOLD
    1984 Kaw KLT200C - Parting Out ( LMK if you need parts! )
    1985 ATC 250ES Big Red
    2005 TRX650F Rincon
    2007 Chinese (haha) 150cc camo atv
    Dec 2009
    oregon
    116
    how would i make it so i doesnt do that anymore?
    Dec 2009
    Whiteland, Indiana
    69
    i usually, put alittle motor oil (straight 30 weight) on mine when i put them back together, keeps them smooth.
    2005 TRX650F Rincon
    Baltimore, MD
    6,088
    Throttle cables and parts in the thumb throttle assembly need occasional lubrication as well as other parts on the trike. If you had any water moisture in the carb or the throttle cable, it could have temporarily frozen.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2009
    oregon
    116
    well i did flipp it in the snow earlier in the day but after 5 hours would it stilbe there and just freeze all of a sudden?
    Dec 2009
    Whiteland, Indiana
    69
    it could, never know, lube it all up
    2005 TRX650F Rincon
    Dec 2009
    oregon
    116
    ok ill do that tomorrow along with all the other maintenance i have to do thanks for all the help
    Dec 2009
    Whiteland, Indiana
    69
    yep no problem
    2005 TRX650F Rincon
    Nov 2008
    Coon Rapids, MN
    956
    check to make sure that the cable is not binding were it splits into two cables for the oil injection and the throttle.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Feb 2009
    michigan
    2,387
    pull the slide out and lube,light oil or it will stick.also lube and check the routing of your cables.
    1985 ATC 250R
    . Team Red Trike
    Baltimore, MD
    6,088
    Of course if your tank was low on fuel, when you went up the hill, you could have been lean/starving your carb for fuel which would cause the trike to rev. Just a thought.
    Nicholson 185s
