Thread: a couple powdercoating questions
    85200xrider's Avatar
    85200xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Cranston RI
    293
    ok so the wife bought me a powdercoating system for xmas.originally i was going to use my inlaws shed and his compressor. but his compressor has an inline oiler. so im going to buy a compressor for my workshop.
    the problem is...my workshop is in my basement. the wife is asking if there is any odor with powdercoating. i have no clue because i have never done it.
    http://www.harborfreight.com/cpi/cta...emnumber=93271
    is that going to be a sufficient compressor to run it?
    i have both an oven and a toaster oven for the baking process but i dont have one big enough to do my frame.
    will a automotive spray booth be good enough to powdercoat my frame? my wifes uncle owns a shop and i figured if that would work i could rent his booth for a little bit in order to powsercoat my frame
    Oct 2009
    brazil indiana
    836
    i don't think a booth will get the job done. you have to maintain i think 300 degrees for 20 or 30 minutes. a friend built his oven and insulated it and uses a salamander heater for heat.
    Jul 2008
    MD
    911
    My powders don't cure until 450 deg.. Only way to a frame is a larger oven or make one.
    As far as the basement goes.. I powdercoat in my basement. I have no problem with fumes at all. Practice on small parts first to make sure you have a thick enough enough coating on it.
    Feb 2009
    Cranston RI
    293
    Quote Originally Posted by 86trizinger View Post
    i planned on practicing on my small spare parts.
    im jus worried about the fumes because i have 4 kids :-/ 2 of which are under 4
    what is your setup like?
    Get a Craigslist free oven, strip all the junk off of it. You can do nearly an entire engine in one shot.....
    You only need about 8psi to run the gun so just about any compressor will do.
    Get your tape, hooks and plugs at absolutepowdercoating.com - inexpensive yet great products!
