ok i`ve found a nice lonestar axle from a 300ex for my 1985 350x what else do i need to make it fit/work??
cheers steve
cheers steve
HONDA ATC250ESJ 1988
HONDA 250R `85 restored SOLD
HONDA ATC 350X `86 restored SOLD
HONDA ATC 250ES `87 SOLD
YAMAHA YZ100 `80 project
HONDA ATC350X `85 PROJECT FINISHED
you will need the 300ex sprocket and wheel hubs. The sprocket is the same as the trx250r/250x/400ex/450r also so alot easier to find.
I did the same thing to my 350x.
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
hi jason
do you know if its any thing different that i need as mine is an 85 x and i see yours is an 86??
cheers steve
I have had a stock 300ex axle in my 85' 350x before and it didn't require any special mods. I am currently running a 300ex dual row bearing carrier and I have a problem with the 85' 350x caliper bracket moving my caliper about 1/4 inch to the right and it is very hard to install new brake pads. Has anyone else ran into this problem? I almost want to spend the extra money to have a clean swap with an 86' swingarm so I can use the 86' caliper bracket.
not sure if a 450R brake caliper bracket will work? i was told it will on the 300ex's so i'd think a 350x it would if your using all 300ex stuff.
