Results 1 to 15 of 21
Thread: A couple Tri Moto 175 questions
    Winnipeg Mb
    113
    Hi, i got a free yamaha tri moto 175 last week. I was on holidays now and i just went into the garage and got it running. I just want to ask a couple quick questions. Thanks
    Its 2 stroke oil injection, I want to know if it works, I am pretty sure it does since it smokes like a 2 stroke should,
    Should I run premium in this since Ethonal in regular is hard on a 2 stroke?
    I noticed theres a oil plug on this where you would check oil on a 4 stroke. Is this for trannmission fluid or chain lube or what?
    Thanks again, Brian
    1988 Honda TRX250R
    fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
    1985 Honda Big Red 250ES
    1984 Honda Big Red 200ES
    1982 Yamaha Tri Moto 175
    Please Check Out My Youtube Channel
    http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
    Maryland
    3,077
    The plug is for tranny fluid.
    Just about any pump gas should be fine.
    If it's smoking then it sounds like your injector system works. Just make sure the bottle under the seat stays full and you'll be good to go!
    Winnipeg Mb
    113
    Thanks for the reply. What sort of fluid? Can i use 4 cycle engine oil? do I fill it to the top of the filler neck?
    1988 Honda TRX250R
    Maryland
    3,077
    You can use atf in a pinch BUT I would highly recommend going to a motorcycle shop and getting two stroke transmission oil. I run GearSaver brand 2 stroke tranny fluid in all my 2 strokes. There is a check bolt on the side of the engine just below that cover that has the filler neck on it. You unscrew that bolt and then fill the tranny just until the oil dribbles out that bolt hole. DO NOT fill it to the neck. That's way too much.
    Nov 2008
    Coon Rapids, MN
    956
    Welcome to the forums,the manual says to use 10w30 oil in the transmission and a good quality 2 stroke oil for the motor. When you go to fill the transmission you only fill it until it comes out the lower bolt in that cover that has the plastic plug in it.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Dec 2009
    the ville illinois
    477
    my brother has a tri-moto 125......it smokes like crazy and seems to be burning the trans oil.Is there a seal out inside? or is he putting to much oil in?
    Dec 2009
    oregon
    116
    is your youtube account yamaharules163
    Winnipeg Mb
    113
    Thank You Old-Yellow
    Yes yt125man
    1988 Honda TRX250R
    Monroe MI
    5,787
    I sent you some info.
    You have any pics of your bike?
    Winnipeg Mb
    113
    Here. I am 15, I will link you the video that i took today. I taped up the seat with some foam undernieth it since then
    http://www.youtube.com/watch?v=QAdz3bu_Y1I
    1988 Honda TRX250R
    Dec 2009
    oregon
    116
    hey its curtismundy from youtube
    Monroe MI
    5,787
    You picked up a nice machine, starts right up.
    If you want to know the exact year (82 or 83), post the VIN. Someone else may be able to tell by looking (me, not so smart).
    You can clean those plastics. quite a few threads on it, one here.
    http://www.3wheelerworld.com/showthr...c-How-to-guide
    Nov 2008
    Coon Rapids, MN
    956
    My computer will not allow me to watch Youtube or I would try and tell you what year it is.
    Here is another link to restoring the plastic.
    http://www.3wheeler.org/tech/fenderrefinishing.html
    My feedback.
    My album
    Winnipeg Mb
    113
    How would I mount just my seat onto the chassis, as its hard they are hard to get on and to choke it and fill up oil i always have to remove the fenders. How hard would this be. What is the vent for that goes down the chassis? Is that for air?
    1988 Honda TRX250R
    Nov 2008
    Coon Rapids, MN
    956
    Are you saying you want to get rid of the rear fender and put the seat on the bare frame and I need more info on the vent you are talking about?
    My feedback.
    My album
