Thread: Swing Arm Removal
    Oct 2008
    California
    98
    Swing Arm Removal
    OK so I am having issues with removing the large bolt that connects the swing arm to the frame.
    I have sprayed the bolt and whacked it with a and nothing. I did not want to pound it too hard but I am thinking that is the only option. I read through the manual but that did not help.
    louisiana
    1,499
    your going to need to put some heat on it then get a bog a-s mall and beat the sh-t out of it,also use plenty of lub.if the heat and doesnt work,you gonna have to cut the bolt.
    Signature pic removed,becuase of no helmet.
    That "heat" needs to go to the swingarm area where the 2 pivot bearings are installed as thats usually where there sleeves are rusted solid onto your swinger bolt.
    In many cases, you have to spread the frame a bit and sawzall that bolt out and deal with the rest of it on your bench. Regardless of who owned it before, anyone who goes through this treats there new parts like gold Just take it apart every year, lube it up and your chicken!!
    81k is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2008
    Bowling Green, MO U.S.A.
    152
    If you have access to an air , thread your nut back on and pound on that a bit. It worked great on mine.
    YT 60
    '85 ATC 200X x2
    YF 60
    '02 400EX
    '85 YFM 200
    '99 Scrambler 400 4x4
    '85 350X
    Oct 2008
    California
    98
    OK after sawzalling the bolt free I got it all out. NOW the bolt has the sleeve attached and I heated the SH** out of it. Placed it over a piece of metal with a hole the right size and whacked it several times and NOTHING!! Also the bearing carriers (??) are still stuck in the swingarm. I am about to just buy anothing swingarm!! LOL
