Results 1 to 11 of 11
Thread: my case is cracked
    fort edward, new york
    4
    my case is cracked
    i posted a while ago i thought it was the gasket but today i changed my oils and i looked right in front of the front sprocket is a 3 1/2'' crack damn i guess that without lerry rigging it or replacing the case the is no fix right well anyway thanx why does my chain come off so much anyway?
    Jun 2009
    Tunkhannock,Pa
    904
    what kind of trike do you have
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    What kind of bike? A little more infor would be great. Could be bad bearings in the rearor a loose axel . Swing arm looseor bad bearings.If it it just cracked and not split you can get it welded or jb weld could work if it is just a leak.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    4
    sorry i ride a 1985 200s its in the name though can i show you a pic tommorrow and you can tell me if its fixable
    kinda funny story about this i have a 1987 lt250r frame all set up with atc rear end and engine,airbox cobra exaust its bored .40 over lt250 shocks and a arms and stuff though.
    Trimotomike's Avatar
    Trimotomike is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2008
    Crystal River , FL
    233
    huh?
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    We want pics of both.....
    To answer your questions:
    Chains fall off when sprockets get severely worn, chain rollers and sliders deteriorate and when axle or pivot bearings get worn.
    If you use a dremel, some acetone and sandpaper; You can rough up most cracks etc and try some epoxy.
    Obviously it's better to figure out whats making the chain launch and then replace the case. But, thats the most expensive part and everyone's broke so have at the epoxy. I have a motor I'm fixing with epoxy right now......
    4
    sweet yeah dremel sand paper and some bake kleen i heard jb weld wont work so what kind of epoxy? I have rebuilt the rear end though its tightening it down thats the problem engines to tourqy it pulls it loose pics tommorow
    Nov 2008
    ontario
    1,055
    jb weld will work, the surface must be oil free and it must be mixed evenly and allowed to cure. my 200s had a hole in the crank case from the chain and it held up the entre time i owned it wich was 8 months. it looked like it seeped a bit of oil but just tiny amounts nothing to get worried about
    proud owner of a trx300ex quad and an 85 atc 70
    Nov 2008
    ontario
    1,055
    also make sure you have the chain tensioners in place and make sure you have the right bolts on the carrier, or else its a lost cause
    Apr 2007
    UP of MI
    804
    You could try JB Weld or there's a new product out that is as good, or better: http://www.rapid-fix-glue.com/ A friend of mine got it in at his auto parts store a couple months back. It's a bit pricey ($28 for both bottles) but it's still cheaper than a new case. Check the video on that link. It's pretty cool stuff.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Feb 2009
    michigan
    2,387
    loose chains are the cause of this,if your chain comes off once get it home and fix it properly.change sprockets and chain together when needed.cases get expensive.
    1985 ATC 250R
    . Team Red Trike
