Results 1 to 11 of 11
Thread: What do you think would cause this sound?
    Apr 2009
    Oklahoma
    1,234
    Sep 2008
    845 New York
    2,302
    loose timing chain? deff something in the top end
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    6,818
    sounds like the valve train to me . somthing is loose , worn , or broken . need to first check your valve adjustments and then go from their .
    Apr 2009
    Oklahoma
    1,234
    Thank you!
    Southern MN
    1,875
    Broken rocker arm!!!!! 100% sure....
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Dec 2009
    illinois
    1,765
    My first thoght would be a rocker arm. sounds like there is alot of play, you need to adjust your rocker arms and go from there. It could be the timing chain but it doesnt sound like it.
    Apr 2009
    Oklahoma
    1,234
    Yeah, I checked the valve adjustment today, strange that it starts fine, runs fine, changes gear fine, has not lost any of its power.
    After checking valve adjustment whats next? If it means pulling out the motor, I might just as well put the Timberwolf motor in.
    Aug 2004
    Ab Canada
    4,368
    That thing have a pull start....? almost sounds like you have a busted Spring on one of the dogs..? or electric start...busted bendix spring...Could be a loose gear under the cover...hard to tell with a video...
    1985 Tri-Z-
    Oct 2009
    brazil indiana
    839
    you will have to pull the top off to see what is going on. i would bet that you will find the timing chain bad. if you are saying the valve adjustment did not fix it, timing chain would be next to look at.
    Apr 2009
    Oklahoma
    1,234
    Well I got a really bad bad bottom end knock now, so as soon as the Timberwolf motor arrives from e-bay i`ll be trying to install that in the the Baja frame, I think that I can follow the manual to install it, I think that i`m going to run into 1 problem, the stator wires from the Baja are a different color code to the wire on the Timberwolf stator, does anyone know how I can tell what wires should be going where, or do you think that the best thing to do would be to swap the stators over, so all the wires match up.
    Can anyone give me some tips / advice on how to swap the stators over, looking through the manual, I think I could do it but I have no pullers or anything to heat flywheel up, if I run into trouble any volunteers to give me a hand...
    Apr 2008
    NW, IND.
    842
    Broken valve spring?It will still work but not good.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
