Hey all,
I recently purchased an 85' Yamaha YTM225DX and need to replace the rear bearings. Any advice?
One issue that I am having while preparing to do this is that the Clymer manual describes the bearings as "Rear Axle bearings" but other websites show and list them as "Rear Wheel Bearings".
1. Am I missing something or are they one in the same? (Just different terminology)
2. Do I need to completely remove the rear disc brake set up to replace the bearings?
3. Does the rear axle have to be removed to replace the bearings?
4. Has anyone here ever replaced these before? Any tips or tricks to remove the existing bearings?
Below is a picture that I got from the old 3WW site in the specifications section. The parts in the diagram are #9 and #10.
This is a picture of the rear bearing kit that I bought on ebay. (Moose Racing) The top piece is the same size as the smaller bearing (#10 is the smaller bearing) I believe that is the "Hub Dust Cover" Does anyone know what that piece is for sure? I thought there would be 2 covers in the kit but apparently there is only one.
Attachment 86455
I just want to be sure of what I am doing prior to tearing the bike apart, any input would be greatly appreciated!
Thanks for reading!
. We had to wale on it to drive the axle shaft out ,it goes out to the right side ( standing at the back of the trike ) i hope this helps good luck!!
