Results 1 to 7 of 7
Thread: atc 110 wiring harness - interchangeable?
    Worcester, MA
    1,117
    atc 110 wiring harness - Can I use one of these from a 1983 model in a 1985 engine? If so, anything I would have to swap/take from the 83 model?
    Thanks
    Baltimore, MD
    6,088
    83 to 85 are all cdi, so it should just be a direct swap.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Sep 2007
    100mi west of Chicago
    3,582
    81-85 is CDI. Vealmonkey you might be thinking of when the style changed.
    Rob
    Worcester, MA
    1,117
    Alright, that's what I was hoping for.
    Anyone happen to know if the 200sx ATC wiring harness will directly fit an 86 TRX200SX Fourtrax quad? Slightly off topic but I figured you guys might know.
    Sep 2007
    3,582
    I think it would a long shot since the 200sx has reverse and electric start. I believe the 86-87 200x engine is similiar to the 200sx engine, while the 83-85 200x engine is completely different.
    Rob
    6,817
    I have noticed the pulse generator plugs are different on the 84/85 model from the 81-83 but you can always cut and splice .
    Worcester, MA
    1,117
    Quote Originally Posted by rdlsz24 View Post
    Rob
    Do you mean the 200sx atc did not have elec. start and reverse? Because I believe the four wheeler does. I'm looking for a whole new wiring harness and components as the one I have has no spark.
    EDIT: Also, will a 185 ATC harness work in my 85 110 atc as they're both CDI?
