Thread: will a trx shock fit the 86 250r? what is the difference?
    Jun 2002
    Mississippi
    2,552
    Exclamation will a trx shock fit the 86 250r? what is the difference?
    I see lots of trx shocks for sale and got to wondering if they will fit the atc?
    anyone know?
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Ontario, CANADA
    4,538
    I have a elka elite from a TRX on my 86 R.
    It has a long line, so what I ended up doing is cutting a 3/4 down gap on the airbox and running the rezi line over it with rad hose scrubbers ziptied on.
    Then I mounted it on the subframe with the rubber half C's like normal.
    Hope this helps, cant get a pic the trike is in pieces!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    Yes it fits, You should get the TRX linkage because the bottom shock bolt is bigger. You will also need to use washers on the top shock mount as the ATC mount is about a 1/4 inch wider. Not sure about the shock valving, But it works for me.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    http://www.3wheelerworld.com/showthr...ck-differences I posted that thread a while back when I had bought one. There is a lot of differences.
