Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: KXT500 guys,wiring questions need help please
    Sep 2005
    MICHIGAN
    2,027
    i posted the links where the KX500 owners used both KX250 and KX125 electrical systems. Yes the timing curves are likely different as i know they are between a LT500R and LT250R. But this does not change the fact people successfully used other complete electrical systems on the KX500.
    You are asking to mix the KXT250 CDI with the KX500 stator and flywheel, most people dont mix these parts but you are welcome to try.
    The stator output and possibly the flywheel from 1986 KX500 was the same as 1986 KXT250.
    86 T3
    84 T3
    86 KX250
    danimal95's Avatar
    danimal95 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    il
    289
    Quote Originally Posted by nd4speed View Post
    no i was thinking of mixing KX250 cdi and harness with the kx500,of coarse this is only if he didnt send me the kx5 cdi,which he may have.......im just trying to get my ducks in a row in case i need some parts,i hope to have this pretty much finished up bt the end of the week,so i dont wangt to be doing all this research at the last minute
    2003 banshee ported jugs,piped,yad-ah,yad-ah
    1986 tecate KX5 swap
    1986 350X(cammed ported piped)sold
    1985 250R(310 klemm pipe)
    1985 atc70 x 2
    other toys
    1995 mustang cobra 6 speed twin turbo
    1075 rwhp 963 rwtq
    9.25@156mph
    1992 GMC typhoon 402c.i. LS1
    4L80E AWD twin turbo a/c power steering and cruise
    963 AWHP
    9.40 @ 147 on 4 drag radials
    danimal95's Avatar
    il
    289
    well ijust located a harness and a good cdi box for $60 so im just gonna get that,it would be a good idea to have a good extra even if i have one already
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    Sep 2005
    MICHIGAN
    2,027
    to me the stator and flywheel will just produce the current and the CDI will time it, but here is the problem I see with that: how will you set the timing? the mark on the stator is for KX500, the spark will fire at timing for KX250, using degree wheel and TDC will put you where?
    86 T3
    84 T3
    86 KX250
    danimal95's Avatar
    il
    289
    thats the part i wasnt sure of either?
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    Aug 2004
    Phoenix
    1,226
    Timing is something I wouldnt play around with unless you have lots of time to tinker and knowledge of setup. Yes there are people that have put complete kx250 ignitions on Kx500's but you will need degree wheel and timing light. And alot of times you never hear a long term ride report to conclude if it was a true success or not. Too much advance, not enough retard and vice versa on different models ignitions make for extreme savvy tuning, sure it can be done but for the safest and best situation right from the start would be what the Kawasaki engineers did the work for us already with the original K5 ignition.
    4 Strokes are NOT the wave of the future!
    Sep 2005
    MICHIGAN
    2,027
    The original KX500 ignition is the way to go and the easiest. The guy who built the fastest KX500 in the world swears by the OEM ignition parts for the average user.
    86 T3
    84 T3
    86 KX250
    Aug 2004
    Phoenix
    1,226
    I agree, plus it will be easier starting and you can add a lighting coil no problem when the time comes.
