Results 46 to 60 of 68
Thread: FatCat 250sx Pictures! FINISHED!!!
  1. #46
    Dec 2007
    Quebec,Canada
    1,014
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
  2. #47
    Worcester, MA
    1,117
    I am still really impressed and would love to build one.
    What parts came off the GS650G? Was it just the swingarm, differential, and driveshaft? Or 'final drive' (or is that another term for differential??).
    Also what did you use for a rear tire/rim and axle?
    And are those rear shocks off the 650 as well? Thanks a lot!!!
    By the way, I looked at those threads and you did an amazing job on the fenders and tank/frame cleaning up. Did you just paint them? They look as good/better than factory!!
  3. #48
    Dec 2007
    Quebec,Canada
    1,014
    Thanks for the comments,The final drive is from the gs650 and right and left section of the swingarm,I keep the SX part that goes to the frame and by chang they have the same diameter.The rear rim is from the SX,I cut 1 inch and weld it in the center to be able to center the wheel in the swingarm.The axle is a front axle from a 200es if I'm correct.The hub and backing plate are from a 250es.The drive shaft is a part of the gs650,and a part of the SX,Tire is 22x11-8.Shock are from a gs550e.Plastic are painted,the white section in the side panel are adhesive tape.The rear fender is a part of a broken 200es front fender.I built the complete bike,and after completly dismantle to sandblast everything
    I'm very curious how much I could sell the whole setup on ebay,except for the upper shock mount,the swingarm and the seat/fender is a direct bolt on to any SX in 30 minutes.
    Attached Thumbnails Attached Thumbnails DSCF4855.jpg   at250sx 003.jpg   DSCF4850.jpg   DSCF4854.jpg   DSCF4853.jpg   DSCF4856.jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  4. #49
    Nice JoB!!!!!! you did your homework !!!!! thats,,,,, a cool bike....
  5. #50
    Worcester, MA
    1,117
    Any plans for fitting a battery anywhere for electric start?
    And when you cut 1", was that from the swingarm or around the center of rim? Looks like the middle piece of rim (from the GS650?) is welded there, and then I assume connected to the brake drum?
    Looks real good. What type of paint did you use for tank/fenders, and did you clearcoat to make them shine?
  6. #51
    Dec 2007
    Quebec,Canada
    1,014
    I have a battery under the seat to help light and indicators,I bought the sx with a bad starter and gear so I completly remove it to save weight,The battery could be installed in the trunk too.I cut 1 inch in the center of the rim,on the brake side to change the offset.The part welded to the rim that hold the spline for the final drive is a old sprocket,welded to the rim,and bolt the parts on it.The 250es hub is bolted in the stock holes of the SX rim.Paint is an enamel with 2 clear coat.Brake cable is the stock SX
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  7. #52
    Mankato Minnesota
    147
    Awsome! Ive always wanted one of those! The rich kid down the street had one when I was a kid. He never let me ride it.
  8. #53
    RiJiD-WILL's Avatar
    RiJiD-WILL is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    los angeles
    271
    too cool thanks for all the details!!!
    were you talking about selling the setup to convert any 250sx to two wheels or selling your convertible bike/trike25sx?
  9. #54
    Worcester, MA
    1,117
    Amazing job, I'm going to start gathering parts! Any plans for a 25" rear tire or sticking with the 22?
  10. #55
    miami
    71
    love the 70 looks awesome
  11. #56
    Dec 2007
    Quebec,Canada
    1,014
    Quote Originally Posted by TheRealFatShady View Post
    I would prefer the 22 ,25 will be too big,clearance problem with the inner fender
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  12. #57
    Tiverton,R.I.
    That SX is awesome I been trying to figure out how to do it with the drive shaft,did you use the swing arm from a honda shadow or something like that.
  13. #58
    Dec 2007
    Quebec,Canada
    1,014
    front section of the swingarm is the stock SX,the rear is from the gs650,with the gearbox,drive shaft is also the same,250sx and gs650 welded
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
  14. #59
    Nov 2010
    Oshawa, On, Canada
    2,123
    it was better as a trike =(
  15. #60
    Dec 2007
    Quebec,Canada
    1,014
    don't be worry,I have not use a good running trike to do it.The rear end was destroyed,fender was broken,and engine was smoking
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
