Results 1 to 11 of 11
Thread: 1982 Honda 110 suspension
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    Where can i buy rear suspension for a 1982 Honda 110. Also will 185s forks work on it?
    Baltimore, MD
    6,088
    185s forks will bolt on and it will give you front brakes as well. As far as rear suspension, you can't just buy a kit, you would have to buy a whole aftermarket frame to get 110 rear suspesnion. Right now I know of only 3 or 4 aftermarket suspension framed 110s. You would be better off building a suspension framed 185s. Of course I say that since I don't have a suspension 110 frame to sell you, but I do have a suspension 185s frame I could sell you! LOL The stock stamped steel frame would not stand up to the punishment of nor would it lend itself very well to the addition of rear suspension. That is why companies made whole aftermarket suspension frames. Also if you do happen to find a suspension 110 frame, I think it would be a little costly since they are so uncommon unless you got one from a really good friend or someone who really didn't know what they had. Best of luck in your search though. I just picked up a suspension 110 frame at the end of last summer and I've been trying to buy one for many years.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2009
    Wright City,MO
    313
    so you think i should just find a 185s frame and buy the suspension kit. but the forks should bolt right on?
    Baltimore, MD
    6,088
    The 185s forks will bolt on to your 110. And if you want rear suspension, you are either going to have to be patient and do alot of shopping around or find you a trike that has more common rear suspension or more commonly available rear suspension kits or just buy a trike that came from the factory with rear suspension. I've done alot of searching to get every suspension kit that I've ever had. And some I had to make bits and pieces for them to work since they are really hard to find anymore.
    Nicholson 185s
    Sep 2007
    oregon
    2,292
    rofl, its called a 200x... unless you want to fab a 185s with rear suspension...
    Dec 2009
    Wright City,MO
    313
    will that bolt on a 82 110 frame? or do i need to buy a different one
    Baltimore, MD
    6,088
    You would have to buy a different frame. Here is a pic of my suspension 110 frame without anything on it but the swingarm and you can see it's totally different from a stock 110 frame.
    Nicholson 185s
    6,810
    Dickson
    Here is another frame for the atc90/110 with rear suspension .
    Dec 2009
    Wright City,MO
    313
    Thanks guys that helps out a lot
    COLORADO
    685
    I can give you a full set of plans for your suspension. I made one for my Custom 200 from scratch cuz I couldnt afford a 200x. Works amazing, easy to make, bulletproof. You can use the stock axle off the 110 as well. all you need to make are arms, a shackle, and axle mounts.
    PM me for details.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Dec 2009
    Wright City,MO
    313
    The plans would be a big help at this point because im looking for a project for shop class at school
