I would like to install a RPM Dominator II axle from a 300EX in a 86 350X. The offset of the sprocket hub on the 300EX axle is not correct for the 350X, it is too far from the swingarm, all other dimensions appear to be the same. I have contacted RPM about a custom sprocket hub and I need to provide the dimensions of the sprocket hub that is needed to make this work. I have two 350X axles, but neither sprocket hub is in good condition and I am not confident that my measurements are accurate. The measurements that are needed are: from the surface of the sprocket hub that contacts the inner bearing race to the surface the sprocket mounts to, and from the surface that contacts the inner bearing race to the snap ring groove on the axle. If any one has a 350X axle in good condition and would be willing to post these measurements it would be very helpful. Thank you in advance.
