Is there any way to put my 85R tripples and forkson my 84R frame?
Aint' no wayz like side wayz!!!
84 200X (SOLD)
84 250R #17 AirCooler Current Racer
85 250R (in progress parts needed)
press your stem out, have it pressed into the new tripples. why do you need an extra .75 of tavel?
If im not mistaken, the 85+ year R forks are bigger in diameter as well. Side wayz, run some progressive springs and spacers if you need it in them 85 Forks and youll be golden.
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
Well when I got the 84R th left fork was bent a lil, and thats what I ran with at Summit. I did buy a set of so called 84R forks and tripples from Ebay but when I got them they where 84 200x. So I have a set of 85 forks with just the upper tripple, or I have the 200x complete set. What do you think I shoild do?
84 200X (SOLD)
I have a spare set of tripples and stem if you need them? im pretty sure I still have them laying around....
#NOLINK
#SUSPENDTHIS
When you say press the stem out, you mean just take the 85R stem out of the tripples and use my stem from the 84R? Thanks.
84 200X (SOLD)
Sidewayz,
I run 85/86 front end on my 84 R. Here is all I did:
Remove steering stops from frame (either grind or cut) - install complete 85/86 250R front end (triples, forks, wheel, axle - everything). then once all is in place - re-weld new steering stops on. I find the 3rd Gen 250R forks to be perfect on my air cooler. Pretty easy mod too - if you have all the parts - it is a one night job.
they work awesome for choppy terrain as well as BIG jumps
