Results 1 to 13 of 13
Thread: KTX500 guys(or carb gurus)having an issue with starting
    danimal95's Avatar
    danimal95 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    il
    289
    on my KXT5 i have a hell of a time starting it,i dont believe it is just my kicking procedure,here are the symptoms:starting from cold,i have the kill switch off and kick it slowly through the range 2 time to draw fuel in,i have also just attemoted to start it with the switch on and gave it hell right off the bat seemed to make no differance,choke fully on it will pop through the xhaust a few times but wont fire....i can then shut the choke off and kick it,sometimes it will fire sometimes it will just pop some more,if it continues to pop i have to hold the throttle wide open and then it will fire.obviously this tells me that it is too fat,however when it is running it will idle fine and have really good throttle response.which makes me hesitant to change out the pilot jet.also it should be known that i have to kick this thing between 10 and 15 times before it will fire,and usually 3-5 times before it will even pop out the exhaust.when it is warmed up it will restart and the 1st or 2nd kick......any ideas???
    2003 banshee ported jugs,piped,yad-ah,yad-ah
    1986 tecate KX5 swap
    1986 350X(cammed ported piped)sold
    1985 250R(310 klemm pipe)
    1985 atc70 x 2
    other toys
    1995 mustang cobra 6 speed twin turbo
    1075 rwhp 963 rwtq
    9.25@156mph
    1992 GMC typhoon 402c.i. LS1
    4L80E AWD twin turbo a/c power steering and cruise
    963 AWHP
    9.40 @ 147 on 4 drag radials
    Feb 2009
    michigan
    2,387
    go up on the pilot jet.not fat at all.bigger pilot will not affect your throttle response
    1985 ATC 250R
    . Team Red Trike
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    First, what are you running for your air filter set up. If you just have a pod filter and no box it will affect your jetting alot. The stock 500 set up with the airbox is even restrictive for that big motor. Your jetting will be lean if your just running a pod cause of all the extra air your getting to the motor so you need more fuel. Like Harry said go up one on your pilot. I think that bike had a 45 pilot, go to a 48 plus check your needle clip position. It should be in the middle move it down one and try that.
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    danimal95's Avatar
    il
    289
    i am running a pod filter,already adjusted the clip down 1,seemed to make no differance for starting,it did clean up the rest of the powerband.wouldnt me having to hold it wide open represent a fat condition???
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    Dec 2002
    Orange County, NY
    1,772
    It would unless holding it wide open like that is getting the fuel in that you need to get it started. A backfire pretty much always indicates a lean condition or if it had the original T3 motor a stator on its way out. LOL! The needle being raised shouldn't have any effect on closed throttle starting. I would try going up on the pilot as was suggested. What carb is on that thing?
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Mar 2009
    Puyallup, WA
    265
    The KX500's all ran 39mm PWK in the 90's and up models. That pod filter will definately need more fuel. Moving the needle clip affects your mid to wide open throttle. After you get the pilot adjusted your most likly going to need to go up on your main jet also. Probaly the 2 sizes bigger on the main, you wont know for sure till you can actully ride it. When you get to that point get a good spot to do some good 3rd or 4th gear roll on plug checks.
    Trikes
    Bikes
    Dec 2002
    Orange County, NY
    1,772
    I figured that's the carb it used. Fantastic piece IMHO, I've been running one on my 250R for 15 years now.
    1986 Monstecate
    1984 ATC125M
    Mar 2009
    Puyallup, WA
    265
    Same carb I have as well, instant HP on a 250R. It was a huge difference soon as I put it on turn that thing into a whole different trike
    Trikes
    Bikes
    danimal95's Avatar
    il
    289
    Quote Originally Posted by JohnR. View Post
    yeah i never looked at it that way,i agree on the back fire being lean,im used to having toi go WOT to start a flooded car(injected)it is the PWK39mm
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    Mar 2009
    Puyallup, WA
    265
    Just a good starting point and usefull info for jetting
    http://www.eddie-sanders-racing.com/...c7aa94d8694ba6
    Trikes
    Bikes
    Masshole
    2,191
    They all have their little tricks to get them started. The best starting 500 ive ever seen is the one I sold over the summer. I should have kept it. After I figured it out it was simple, tip it on its side till gas came out the carb, slowly kick it over 2-3 times with the throttle wide open, then find tdc and go PAST it a little, choke back up on the kicker and give it one hard slam and it would always start one kick. Try going past tdc like I just said, It may work. If you tried it at tdc you could keep kicking till you were blue in the face and it would never start with the last bike I had.
    danimal95's Avatar
    il
    289
    so i did some looking today,it has a 52 pilot and a 168 main...i swapped in a 55pilot and left the main as is,does the same exact thing...kick a few times gets a pop out the exhaust,turn choke off,and it almost fires w/o touching the throttle....were do i go fom here???
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    Mar 2009
    Puyallup, WA
    265
    Check your air fuel screw, make sure its at 1.5-2.5 turns out When it does start up how is the idle with that pilot? Some of my bikes just plane dont like any choke but run fine with the jetting that I have in them. Try going up again on your pilot to a 58 and pick up a main as well. Depending on what year your engine is the stock jetting jumps around alot through the years. A few years ran 60 pilots and 172 mains while others dropped down to 55 pilots and 168 mains. This is the crappy part about jetting its trial and error till you get it right especially with your open pod filter your most likely going to be up in the 175 or higher on your main. Keep us posted.
    Trikes
    Bikes
