Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: ATC185 and ATC185S Technical Data
    Minnesota
    I have a 1982 185s and there is oil leaking from the cdi cover..any ideas why?
    Nov 2012
    Canada
    4
    I have an 83 185s, and need to replace the front and rear sprockets, does anybody have a step by step guide to do that? I'm new to the three wheeler world and need as much help as I can get with it.
    Jan 2014
    VA
    I also have a 185 3 wheeler and there is oil leaking from around the cdi cover.. What is causing this?
    Jan 2014
    VA
    I have an 85 250 r, I bought it sec. hand and it's been totally restored and a bigger carb and all new reids.. It was idling fine when I got it, not it doesn't want to stay idling. Could the gas mixture be too rich? It does smoke more than it should I think, but didn't do that wn I first got it. I haven't ridden it but a lil. I think that I may have mixed the fuel too rich in fear of mixing it too lean....
    Jul 2015
    gimli,mb
    I have a 83 185 and it has front suspension yet it says above that it doesn't come with it Iwas told it was a 84 but when iI typed my vin in it said 83 bit couldn't show make etc how do I figure out what model I have as I need some parts like the recoil and the front sprocket is missing the c clip and a bolt which I believe is why my chain jumps. Any ideas
    Jul 2016
    california
    I have an atc 185 and im having the problem that wen i accelarate from 0 to 100 right away it will just wanna cut out and if u hold it there itll just die
