The main reason behind the Hi Performance ATC frames being kind of long in the front is so the same frame could hold different engines better and all they would have to do is change the engine mounts. Sort of a "universal" frame for lack of a better term. I have one of those frames currently with an RD350 engine, but I do have an H2 engine also that would bolt right in by just fabbing the engine mounts. Also the early aftermarket frames wether Hi Performance ATC or other makers were mostly rigid is because the trikes of the time were rigids. Most of these frame makers were popping up towards the end of the 70s and there weren't trikes with suspensions yet. But it didn't really matter as most of these trikes were for the sand where a rigid frame is more forgiving. There were also companines that popped up using custom made swingarms that would use a street bikes dual rear shocks and that was right around the time as the 250r was making it's debut. Once the 250r arrived on the scene, it seemed that everything changed and all the frame makers switched over to what the customer wanted and that was "suspension" frames. Most of these frame makers were also making conversion kits to turn a hard tail trike into a suspension trike. And some of these kits were really rather ingenious if you see them. If you are dragging on dirt, a suspension frame is a big plus unless you are running at a track where they are really on top of the surface conditions of the track, which it seems very few do. Surface maintenance has a tendency to slow down the racing quite a bit. Those old frames are still out there though. I mean, I found one in a shed here in Baltimore, Maryland of all places! It really seems the best places to watch for things like that is around the popular desert spots out on the left coast. Pismo, Glamis and places near areas like that are great spots to find older, unwanted, unique trikes. It just takes some searching and being in the right place at the right time. And you could always post an ad in one of those kinds of places local newspapers stating what you are looking for. You may get lucky. In the tougher economic times, people are a little more willing to cut loose that special project that has been sitting in the back of the shed. Best of luck with your hunt.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
