Do the 1984-1985 Honda atc 110 and 125m inter change? Ff they do what parts other than the cylinder and piston what else can i use for my atc 125m? Thanks![]()
I 2nd the question. I have been advertising locally for 110 parts/machines, and have gotten two replies for a 125m.
In this article, it is referenced that the original poster had a 110 converted to 125m:
http://www.3wheelerworld.com/showthr...s-given-a-125m
It sure looks like the same frame and plastics, so is it just the upgraded engine w/ electric start? Is the tranny the same? If so, is that why I see a lot of tranny problems for the 125m, and none mentioned for the 110?
Well, it could be a complete coincidence...
Here is my thought pattern:
Someone answered my craiglist ad with a 125m with transmission problems. (I haven't gotten any details on it yet.)
I have absolutely zero experience with the 125m, so I did a search here, and three threads showed up:
http://www.3wheelerworld.com/showthr...on-part-needed
http://www.3wheelerworld.com/showthr...-125m-low-gear
http://www.3wheelerworld.com/showthr...-when-shifting
BTW, while looking for the tranny info, I ran across this quote: "The 125m and 110 have the same sub trans. shaped differently but insides go together the same way."
I have a 1985 atc 125m that had taken the low gear and the cross over shaft out of the sub transmission and the other one I have was just a lose bolt on the shift locater lobe!
Cool. Hopefully this one I'm looking at will be an easy fix...
