Results 1 to 15 of 21
Thread: Cool DirtWheels article 89 250R vs 09 450R Honda
    Sep 2007
    100mi west of Chicago
    3,582
    In the March issue of DW. I would love to have either of these quads. Their conclusion is kinda lame since they don't take a side, but still a cool shootout.
    http://www.mediafire.com/file/tkzgz1...250Rvs450R.pdf
    Rob
    Sep 2007
    oregon
    2,292
    it is kind of lame for them not to choose a bike. Its funny though how a 20 year old bike is hanging with something fresh off the line in 2009. What there not saying is that the 450r has a 80% increased stroke along with a high compression motor, and yet a mere 89 trx250r with 36hp is still able to keep up..rofl.
    na
    5,702
    My buddy just called and told me about this. He is a avid 2 stroke guy.
    The fact is, DW will probabaly never publically admit that the 250R was light years ahead of it's time and that the 450's are barely a comparision once you factor in all aspects between the 2 ATV's.
    They are more of a advertising mag, and the manufatures would frown on them pimping a 20 year old 250R over a new modern machine that they are trying to sell in these times.
    I dont blame them for that, but.....
    2 strokes rule!
    Proudly NOT a member of
    "Team on the Teat"
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I can't believe they even admitted as much as they did about the 250R being better than the 450. Honda must not be spending too much advertising dollars lately
    Dec 2002
    Kansas
    2,387
    That was a good read. Put equal shocks on both and a low end pipe on the 250r and do a retest.
    I had the RIGHT to remain silent, I didn't have the ability!
    Sep 2007
    oregon
    2,292
    _____________________________________________
    Aug 2009
    Newfoundland, Canada
    915
    thanks FactoryX, I couldnt open it
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    They did point out the one thing 4-strokes have going in their favor, and that is the ability to pull a gear much longer.
    I ran with a lot of 450R's and YFZ's on the ice last year. They weren't any faster on the straights. They were a bit better into the corners, and coming out being able to just pull a gear. On a 250R, it takes a shift or two. Made a bit of a gain for the 4-strokes, and as long as the rider didn't mess up, it was a slow but steady gain through the laps. Otherwise, I felt they were no better on the ice oval. Once I get my 330 setup, I don't think they are gonna like me
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i think you could eliminate shift lag with a switch attached to the gear shifter so when you hit the shifter, it retards or kills the spark altogether, for just that split second and kills motor power just long enough to shift, them it comes back on full force. shifts would be so quick, you'd never have to let off the gas or touch the clutch
    Sep 2003
    Elizabethtown PA
    1,581
    Cool article but did you notice how they said 250r's had single piston caliper on the front when they were dual piston.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Blossvale NY
    4,563
    way cool article!! The old 250r set the bar pretty high, im not surprised they arent able to say that the 450 is light years ahead of the old pinger... LONG LIVE THE 250r!!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Sep 2007
    3,582
    I see they also posted this on their site about 8 months after I first posted it from the mag
    http://www.dirtwheelsmag.com/ME2/dir...DE41DD0687A1A7
    Rob
    Jun 2003
    englishtown NJ
    2,676
    that article was quite inaccurate when you start to look closer. they say its a 89, but its really a 86 frame, 88/89 swinger and motor, 86/87 spindles, 88/89 a-arms, as noted single piston calipers and general mismatch of all year parts. Article was far from accurate in machine specs, but it got the general point across, HONDA GET OFF YOUR BUTT AND MAKE SOMETHING THAT WILL BEAT WHAT YOU MADE 22 YEARS AGO. The article that really was a sham was the one that one of them did comparing a 09 ltr450 to trx330r, the ltr won in everything, they did something to the 250r to make it handle and ride so bad, its almost like they ran the 250r with way too big of jets or with it fully choked the whole time.
    Blossvale NY
    4,563
    Quote Originally Posted by deathman53 View Post
    Most definitely... It would take quite a bit to get any of the 450 thumpers to run with a decently set up 330r. And yes, I used the term "decently" intentionally!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    4x4van's Avatar
    4x4van is offline At The Back Of The Pack Arm chair racerFirst time rider
    SoCal
    160
    The reality is that a 2-stroke will always eat a 4-stroke of equal displacement alive. Not long ago, Supercross was 250cc (2-strokes) in the "big show" and 125cc (2-stroke) for the "lites". Then, one rider tried a 4-stroke in the 250 class. But they had to change the rules to allow that 4-stroke to have much more displacement in order for it to be competitive, since a 250 4-stroke would have never been able to keep up with the 250 2-strokes. I can't remember off the top of my head who it was, but it was a top factory rider (yamaha, I believe), and it was at a Supercross race here in SoCal...I was there, and it was really strange to hear the normal buzz of all the 2-strokes, and then the low growl of a single 4-stroke on the track! But by the end of the next season, 2-strokes were pretty much phased out of supercross.
    Now supercross runs exclusively 450 (4-stroke) in the "big show", and 250cc (4-stroke) in the lites. Basically, to get the power of a 2-stroke out of a 4-stroke, you must double the displacement (which makes sense since the plug fires every time the piston reaches the top on a 2-stroke, as opposed to every other time on a 4-stroke). Combine the fact that in an equal frame, a 2-stroke is typically lighter than a 4-stroke, and the fact that there really hasn't been much major advancements in quad suspension since the late 80's, and the result is that a healthy 250 2-stroke will usually meet or beat a similarly healthy 450 4-stroke.
