Any one know where the other timing mark is that I am supossed to line up with?
theres a bolt above the pull start assembly u need to remove it and may need a flashlight you will see the mark u need to be lined up with the t mark
there is a very small triangle right above the timing chain aline in time just make sure the piston is up
